HP Pro 290 G9 SFF Intel Core i3-12100 8GB 256GB SSD Windows 11 Professional
Quicklinx: HMTSWS00 Mfr#: 6B2R8EA#ABU
£523.62 ex VAT
£628.34 inc VAT
The HP Pro SFF 290 helps optimize business resources. Equipped with a powerful Intel processor, essential tools, and security features for business, this affordably priced and easy to set up PC has a scalable and functional design that can grow with your business.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • High performance, high portability
    Get the exceptional combination of responsive performance, connectivity and speed with a 12th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • Simple PC management
    Spend less time and get right to the updates you need with HP Support Assistant.
HP Pro 290 G9 - SFF Core i3 12100 3.3 GHz - 8 GB - SSD 256 GB - UK
Personal computer - SFF
Intel Core i3 (12th Gen) 12100 / 3.3 GHz (up to 4.3 GHz, (Quad-Core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
12 MB L3 Cache
Cache Per Processor
12 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express 3.0 - M.2 2280 - NVM Express (NVMe)
Optical Storage
DVD-Writer
Graphics Controller
Intel UHD Graphics 730 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 11 Pro
Software Included
HP Support Assistant, McAfee LiveSafe (1 year subscription), HP Setup Integrated OOBE, HP System Event Utility, Dropbox (25 GB Cloud Storage) (free for 1 year), HP Documentation, HP Audio Switch, HP JumpStart, Xerox DocuShare (90 days trial)
9.5 cm x 30.3 cm x 27 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
4.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H670
Cache Memory
Installed Size
L3 Cache - 12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
2933 MHz
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0
NVM Express (NVMe)
Storage Controller
1 x SATA
Channel Qty
3
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 125
USB
Localization & Layout
Mouse
Mouse Name
HP 125
USB
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 4.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2242/2280
1 x headphones/microphone , 4 x USB 3.2 Gen 1 , 4 x USB 2.0 , 1 x audio line-in , 1 x audio line-out , 1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet)
Security cable lock
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
CSA, UL, RoHS, ETS 300 826, WEEE, ETS 300 328, FCC CFR47 Part 15 C, LVD, CECP, SEPA, IEC 950, ErP Lot 3 2013 Ready, Japan PC Green Label, Taiwan Green Mark, Korea Eco-Label
Power adapter
Power Provided
180 Watt
Operating System / Software
OS Provided
Windows 11 Pro English
Software
Sustainability Information
ENERGY STAR Certified
9.5 cm
30.3 cm
27 cm
4.2 kg
Shipping Width
19.6 cm
Shipping Depth
49.9 cm
Shipping Height
34.2 cm
Shipping Weight
6 kg
5 °C
35 °C
5 - 90% (non-condensing)
Warranties (2)
HMTS HP Care Pack Next Business Day Hardware Support - Extended serv In Stock £35.99
HMTS HP Care Pack Active Care NBD Hardware Support - extended service agreement - 3 years - on-site In Stock £53.71
Monitors (9)
HMTS HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £161.91
HMTS HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £320.60
HMTS HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £614.57
HMTS HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £163.00
HMTS HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £74.99
HMTS HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £114.10
HMTS HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor In Stock £132.34
HMTS HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £81.50
HMTS HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £261.63
Other bundles (45)
HMTS HP 325 Webcam In Stock £18.24
HMTS Poly Voyager Focus 2 UC-M C USB-A WW In Stock £99.99
HMTS Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.59
HMTS Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £108.16
HMTS Poly Voyager 4320 UC V4320 C USB-C WW In Stock £103.93
HMTS Poly DA85-M Sound Card In Stock £44.59
HMTS Poly Blackwire C3225 USB-A Headset In Stock £30.37
HMTS Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £67.64
HMTS Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £44.79
HMTS Poly EncorePro HW510 Mono Headset (N/C) In Stock £70.21
HMTS Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
HMTS Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £93.07
HMTS Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £119.53
HMTS Poly Voyager 4310 UC V4310-M C USB-A WW In Stock £98.43
HMTS Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £117.28
HMTS Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £110.60
HMTS Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £110.24
HMTS Poly Voyager 4320 UC V4320 C USB-A WW In Stock £86.60
HMTS Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £117.65
HMTS Poly Sync 10 SY10-M USB-A/C WW In Stock £53.59
HMTS Poly EncorePro 525 USB EP525 USB-A Headset In Stock £84.76
HMTS Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
HMTS Poly Sync 40 SY40-M WW In Stock £127.22
HMTS Poly EncorePro 525 USB EP525-M USB-A Headset In Stock £42.59
HMTS Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £108.13
HMTS Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £30.35
HMTS Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.77
HMTS Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £66.83
HMTS Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £43.84
HMTS HyperX Pulsefire Core Gaming Mouse In Stock £27.07
HMTS HyperX Wrist Rest In Stock £20.11
HMTS Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.95
HMTS Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £52.80
HMTS Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £25.49
HMTS Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £27.57
HMTS Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £26.20
HMTS Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.88
HMTS Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £77.77
HMTS Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £68.48
HMTS Poly EncorePro 530 - headset - Quick Disconnect In Stock £68.48
HMTS Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £110.24
HMTS Poly EncorePro HW520D - headset - Quick Disconnect In Stock £105.92
HMTS Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.56
Brand: HP
Price Range Ex VAT: £500 - £750
