Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C
Quicklinx: HR76WS00 Mfr#: 8X231AA
Recommended Use: Computer, Portable electronics
Connectivity: Wired
More than 50 In Stock
£66.60 ex VAT
£79.92 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
  • Connectivity options
    Enhanced connectivity for your devices: USB-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity.
  • Comfort and durability
    Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit.
  • Wearing style
    Premium PC wideband audio with noise-cancelling microphone and Digital Signal Processing (DSP) for a more natural voice sound.
  • Simple call management
    Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status.
  • SoundGuard Digital technology provides advance audio protection
    Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound.
  • Enhanced call quality
    Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
Poly Blackwire 5220 - headset - USB-C, 3.5 mm jack
Headset - wired - USB-C, 3.5 mm jack
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 116 dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Microphone
Boom
Microphone Noise Cancelling
Controls
Answer/end, mute, volume
Software Certification
Certified for Skype for Business, Cisco Jabber Certified, Avaya Certified, Certified for Microsoft Teams, Zoom Certified, UC certified, Works With Chromebook Certified
Compatibility
Mac, Windows
165.2 g
Earpad Material
Artificial leather
Recommended Use
280° rotatable microphone
Audio Output
On-ear binaural
Wired
Sound Output Mode
Stereo
118 dB
Sensitivity
116 dB
Impedance
32 Ohm
Diaphragm
32 mm
In-Cord Volume Control
Dynamic EQ optimised
Microphone
Boom
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
Carrying case, USB-C to USB-A adapter
Supported Host Device OS
Windows 10, macOS
HR76 Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.08
HR76 Poly - USB adapter - 24 pin USB-C to USB In Stock £13.36
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Poly
