Ultimate value and speed - HP PageWide Pro delivers the lowest total cost of ownership and fastest speeds in its class. Get quick two-sided scanning, plus best-in-class security features and energy efficiency.
• Multi-function - print, copy, scan, and more
• Get the lowest total cost of ownership and fastest speeds in its class. Get professional-quality color documents, fast two-sided scanning, plus best-in-class security features and energy efficiency
• For teams of 5–15 people printing; prints up to 6,000 pages/month
• Prints up to 70 pages per minute
Count on exceptional value and the results businesses need – print professional-quality colour documents for the lowest total cost of ownership in its class.
Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class. Print professional-quality colour on a variety of papers – perfect for office use. Print more pages and replace cartridges less often, using Original HP PageWide high-yield cartridges. Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology.
Minimise interruptions and downtime with efficient, reliable performance. Conserve resources and use less energy than laser printers, with HP PageWide Technology designed for today’s busy office.
Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand. Conserve with HP PageWide Technology – designed to use less energy than any MFP in its class. Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges.
Best-in-class print speeds, fast printing from sleep mode, and single-pass, two-sided scanning keep productivity on track. Documents are ready fast, so there’s less waiting.
Wait less, do more with unmatched speeds – up to 55 ppm – and the fastest first-page printing in its class. Get fast two-sided scanning directly to email and the cloud with this LDAP-enabled MFP. Manage tasks from a 10.9 cm (4.3-inch) touchscreen. Print Microsoft® Word and PowerPoint® files from USB. Print from your mobile device with Wi-Fi Direct and NFC touch-to-print technology – no network needed.
Help protect your fleet, data, and documents with best-in-class security and fleet management features. Help secure important information and get the tools you need to work efficiently and confidently.
Help protect your investment and extend capabilities as your needs grow, with a portfolio of solutions. Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job. Regulate colour use and reduce printing costs with HP Colour Access Control. Help keep your printer secure – from boot up to shutdown – with secure boot and secure code integrity validation.
HP PageWide: Not Laser. Not inkjet. It's the best of both. A new alternative for business printing
HP PageWide is designed with fewer moving parts. The stationary, page-width print bar enables unmatched speeds, improved reliability, and fewer replacement parts, all with professional print quality at the lowest total cost of operation in its class. -
Colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen. -
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
Easy mobile printing from HP
Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
- HP PageWide Pro 477dw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Page wide array (colour)
- Inkjet Technology
- 4-ink
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4500 pages
- Max Copying Speed
- Up to 40 ppm (mono) / up to 40 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, glossy paper, tri-fold paper, matte paper, punched paper
- Standard Media Capacity
- 500 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, HP EasyColor, Mobile Printing, access point mode, scan to SharePoint, scan to PC, scan to OCR
- Power
- AC 120 V (50/60Hz)
- 53 cm x 40.7 cm x 46.7 cm
- 22.15 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Page wide array - colour
- 50000 pages
- 750 - 4500 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 786 MB
- Max Supported Memory
- 786 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 6 (XL), PDF
- First Print Out Time B/W
- 6.5 sec
- First Print Out Time Colour
- 7 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 300 x 300 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 199 station(s)
- Delayed Transmission
- Remote Fax Retrieval (Polling)
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling, TAM Interface
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 178 mm, 76.2 x 127 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm)
- 500 sheets
- 300 sheets
- ADF - 50 sheets size: 101.6 x 210.8 mm - 215.9 x 297.2 mm , Input tray - 500 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm , Output tray - 300 sheets
- Speed Details
- Scanning: up to 25 ipm - B/W , Scanning: up to 25 ipm - colour , Printing: up to 55 ppm (A4) - B/W draft , Printing: up to 55 ppm (A4) - colour draft , Printing: up to 40 ppm - B/W (ISO) , Printing: up to 40 ppm - colour (ISO) , Copying: up to 40 ppm - B/W (ISO) , Copying: up to 40 ppm - colour (ISO) , Copying: up to 55 ppm (A4) - B/W draft , Copying: up to 55 ppm (A4) - colour draft , Printing: up to 55 ppm (Letter A) - B/W draft , Printing: up to 55 ppm (Letter A) - colour draft , Copying: up to 55 ppm (Letter A) - B/W draft , Copying: up to 55 ppm (Letter A) - colour draft
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 2 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A
- LDAP, SSL, LEAP, TLS, WPA2, 802.1x, WPA2-PSK, EAP-TLS, PEAP
- Operating System Support
- UNIX, Novell NetWare 6, Linux, MS Windows 7, Novell NetWare 6.5, Apple Mac OS X 10.6, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Novell Open Enterprise Server, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Small Business Server 2003 (32/64 bits), MS Windows Server 2008 (32/64-bits), MS Windows Small Business Server 2008 x64 Edition, MS Windows XP 32-bit Edition SP3 or later, Windows 10, MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities, I.R.I.S. OCR, HP Web Jetadmin, HP Participation Study
- Voltage Required
- 100 Watt
- Power Consumption Standby
- 10 Watt
- Power Consumption Sleep
- 4.8 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 3000 pages - HP 913 , 1 x ink cartridge (cyan) - up to 1500 pages - HP 913 , 1 x ink cartridge (magenta) - up to 1500 pages - HP 913 , 1 x ink cartridge (yellow) - up to 1500 pages - HP 913
- ENERGY STAR Certified
- Limited warranty - parts and labour - 1 year - on-site
- 53 cm
- 40.7 cm
- 46.7 cm
- 22.15 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 49.5 cm
- Shipping Height
- 59.4 cm
- Shipping Weight
- 26.39 kg
- Sound Emission
- 56 dBA (operating)
- 15 °C
- 30 °C
- 20 - 80%
Ink (13)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £15.42 |
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £5.06 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.69 |
HP 973X High Yield Black Original PA | In Stock | £99.27 |
HP 973X High Yield Cyan Original PAG | In Stock | £94.18 |
HP 973X High Yield Yellow Original P | In Stock | £94.18 |
HP 913A Black Original PageWide Cartridge | In Stock | £65.11 |
HP 913A Cyan Original PageWide Cartridge | In Stock | £66.97 |
HP 913A Magenta Original PageWide Cartridge | In Stock | £66.97 |
HP 913A Yellow Original PageWide Cartridge | In Stock | £66.97 |
HP 973X High Yield Black Original PageWide Cartridge | In Stock | £99.27 |
HP 973X High Yield Cyan Original PageWide Cartridge | In Stock | £94.18 |
HP 973X High Yield Magenta Original PageWide Cartridge | In Stock | £94.18 |
Other bundles (3)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.65 |
HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm | In Stock | £13.99 |
