HP 973X High Yield Cyan Original PageWide Cartridge
Quicklinx: C721WS00 Mfr#: F6T81AE
Type: Ink Cartridge
Technology: Inkjet
More than 50 In Stock
£109.49 ex VAT
£131.38 inc VAT
Count on professional-quality colour documents for a great value. Get a lower cost per page than standard cartridges and the results you expect every time with Original HP PageWide high-yield cartridges, precisely tuned to HP printers and MFPs.
Print 2.5x more pages at a lower cost per page than standard cartridges with Original HP PageWide high-yield cartridges. Get value your printer was built to deliver with high-volume printing for HP PageWide Pro 400 series devices.
Produce professional-quality colour documents at speeds your printer was built to achieve. Only Original HP PageWide cartridges are precisely engineered to match your HP printer’s high-speed performance, while producing professional-quality prints.
Get professional-quality pages and the performance you expect. Only Original HP PageWide cartridges are specially designed and precisely engineered for your HP printer or MFP – so you can count on fast, consistent results.
Easily replace cartridges in a snap, and tackle high-volume print jobs without interruptions. Original HP PageWide cartridges make printing easy, so you can make the most of your workday.
  • High-volume printing at a lower cost per page
    Reduce costs for high-volume printing – high-yield cartridges deliver a lower cost per page than standard.
  • Print at high speeds – without sacrificing quality
    Count on professional-quality results at high speeds, using Original HP PageWide cartridges.
  • Hassle-free cartridges that simply work
    Spend less time troubleshooting device problems, using Original HP PageWide cartridges.
HP 973X - High Yield - cyan - original - PageWide - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
PageWide
Printing Colour
Cyan (pigmented)
Cartridge Yield
High Yield
Yield
Up to 7000 pages
Compatible with
PageWide Managed P55250dw; PageWide Pro 452dn, 452dw, 452dwt, 477dn, 477dw, 477dwt, 552dw, 552dwt, 577dw, 577z, MFP 477dn
Shipping Width
21.5 cm
Shipping Depth
2.8 cm
Shipping Height
6.2 cm
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
PageWide
Cyan (pigmented)
Included Qty
1-pack
Cartridge Yield
High Yield
Yield
Up to 7000 pages
ISO 24711
Compatible with
HP PageWide Managed P55250dw , HP PageWide Pro 452dn, 452dw, 452dwt, 477dn, 477dw, 477dwt, 552dw, 552dwt, 577dw, 577z, MFP 477dn
Type: Ink Cartridge
Technology: Inkjet
Brand: HP
