HP P27H G4 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: H26YWS00 Mfr#: 7VH95AA#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), DisplayPort, HDMI
£161.11 ex VAT
£193.33 inc VAT
Give your content room to roam on the HP P27h G4 FHD Height Adjust Monitor. It combines business-class presentation features, comfort adjustability, stereo audio, and advanced connectivity in an affordable, contemporary design that's a standout on any desk.
  • Get comfortable
    Find your best view with adjustable tilt settings, 100 mm of height adjustment, and 90° pivot rotation.
  • Create an efficient workspace
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display.
  • Adjust your view
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
  • Complete the picture
    Customize a total solution with options designed for your display, like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter.
  • Responsibly made
    Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT 2019 registered, and low halogen display.
HP P27h G4 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
17 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
62.01 cm x 21.16 cm x 49.86 cm
5.22 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CEL, EAC, CEL Grade 1, ISC, CP65, low halogen, DisplayPort 1.2, IEEE 1680, ISO 11469, ISO 1043
Display Type
Energy Class
Class E
24 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 6-bit + A-FRC Color Depth, 72% NTSC colour gamut
62.01 cm x 21.16 cm x 49.86 cm - with stand
5.22 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) , HDMI (HDCP) , VGA , Audio line-in (mini-jack)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
360
Rotation Angle
180
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), arsenic free, mercury free
1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
17 W
17 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 62.01 cm - depth: 21.16 cm - height: 49.86 cm - weight: 5.12 kg , Without stand - width: 62.01 cm - height: 37.14 cm - weight: 3.1 kg
Shipping Width
69.6 cm
Shipping Depth
19 cm
Shipping Height
45 cm
Shipping Weight
7.17 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
8.0
5 °C
35 °C
20 - 80% (non-condensing)
Accessories (1)
H26Y HP B250 Mounting Kit for LCD Display/Thin Client In Stock £33.61
Warranties (4)
H26Y HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
H26Y HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
H26Y HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.93
H26Y HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
Diagonal Size: 27in
Response Time: 5ms
Interfaces: DisplayPort
Interfaces: HDMI
Brand: HP
