Customize an altogether better solution with the HP B250 PC Mounting Bracket, which lets you attach your HP Workstation, HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind select HP P series Monitors.
 - HP B250 mounting kit - for LCD display / thin client - HP black
- Product Type
 - Mounting kit
- Mounting Components
 - Mount bracket
 - 11.5 cm x 5.7 cm x 18.13 cm
 - 505 g
- Recommended Use
 - LCD display / thin client
- VESA Mounting Interface
 - 100 x 100 mm
 - HP black
- Package Content
 - 4 x 6 mm screws, 4 x 10 mm screws, DisplayPort cable (70 cm), TR screws
 - 1-year warranty
- Designed For
 - HP 260 G4; Elite 600 G9, 800 G9; Pro 260 G9; ProDesk 405 G8
 - 11.5 cm
 - 5.7 cm
 - 18.13 cm
 - 505 g
 - HP black
- Package Content
AV Furniture
 - Mounting kit
 - Mount bracket
- Recommended Use
 - 100 x 100 mm
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
 - 25.5 cm x 13.5 cm x 8.5 cm / 687 g
 - Limited warranty - 1 year
- Designed For
 - HP 260 G4 , HP Elite 600 G9, 800 G9 , HP Pro 260 G9 , HP ProDesk 405 G8
