Make the world your office with powerful portable printing – no network necessary. This quick, quiet printer delivers more pages per cartridge and has a long-lasting battery life.
Easy portable printing wherever you need it
Simply print from your laptop or mobile devices wirelessly, with or without a router.Start printing in minutes. HP Auto Wireless Connect makes setup easy.This durable, compact printer fits in your car, backpack, and more, for convenient printing anywhere. -
Lead the way with fast, easy mobile printing
Reduce charging interruptions with a long-lasting battery.Get the highest page yields of any other in-class printer, using Original HP cartridges.Set the pace for success wherever you go. Keep moving through the day with fast print speeds.Stay productive with a large and easy-to-use control panel. -
High-powered quality and reliability
Power through the workday. Charge from home, in your car or office, and more.Plug in your AC power source to charge within 90 minutes while the printer is off, with HP Fast Charge.Minimise disruptions with premium design and quiet performance. Impress clients, without noisy interruptions.Get high-quality prints time after time with a printer designed and built to be reliable.
- HP Officejet 200 Mobile Printer - printer - colour - ink-jet
- Printer Type
- Personal printer - ink-jet - colour
- Form Factor
- Portable
- 2.1 kg
- Localisation
- Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 102 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 20 ppm - black draft - A4 (210 x 297 mm) , Up to 18 ppm - colour draft - A4 (210 x 297 mm) , Up to 9 ppm - black laser quality , Up to 6 ppm - colour laser quality
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Interface
- USB 2.0, USB host, Wi-Fi
- AirPrint Enabled
- Preview Screen Size
- 2"
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCL 3
- Media Type
- Envelopes, transparencies, greeting cards, labels, plain paper, photo paper, index cards
- Total Media Capacity
- 50 sheets
- Monthly Duty Cycle (max)
- 500 pages
- Recommended Monthly Volume
- 100 - 300 pages
- Networking
- Wireless network extender
- System Requirements
- Linux, Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits)
- 36.4 cm x 18.6 cm x 6.9 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Print Speed
- Built-in Devices
- 2.0" Hi-Res MGD
- 2"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 4800 x 1200 dpi
- First Print Out Time B/W
- 12 sec
- PCL 3
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Path Type
- Straight
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 102 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 76 x 102 mm
- Borderless Photo Sizes
- 100 x 150 mm
- Envelope Sizes
- US A2 (111 x 146 mm), International DL (110 x 220 mm), Com-10 (105 x 241 mm), Monarch (98.4 x 190.5 mm)
- Card / Label Sizes
- 2L (127 x 178 mm), 102 x 152 mm, 127 x 203.2 mm, 100 x 148 mm, 148 x 200 mm
- Media Weight
- 60 g/m² - 300 g/m²
- 50 sheets
- Media Feeders
- 1 x automatic - 50 sheets weight: 60 g/m² - 300 g/m²
- Max Media Capacity
- 50 sheets
Duty Cycle
- 500 pages
- 100 - 300 pages
- Networking
- Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x ink cartridge (black) - HP 62 , 1 x ink cartridge (yellow/cyan/magenta) - HP 62
- CSA, UL, VCCI, C-Tick, BSMI, GOST, EN 60950, GS, IEC950, CCC, EMC, MIC, FCC
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities, HP SureSupply
- OS Required
- System Requirements Details
- Windows 7 - HD 1 GB , Windows 7 64-bit Edition - HD 1 GB , Windows Vista - HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 850 MB , MacOS X 10.8/10.9/10.10 - HD 1 GB
Environmental Standards
- ENERGY STAR
- 0 °C
- 40 °C
- 15 - 95%
- 36.4 cm
- 18.6 cm
- 6.9 cm
- 2.1 kg
- Width (Shipping)
- 49.5 cm
- Depth (Shipping)
- 24.3 cm
- Height (Shipping)
- 11.9 cm
- Weight (Shipping)
- 3.6 kg
Ink (9)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.48 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.80 |
HP 62 Black Ink Cartridge | In Stock | £16.26 |
HP 62 Tri-color Ink Cartridge | In Stock | £19.33 |
HP 62XL Black Ink Cartridge | In Stock | £40.68 |
HP 62XL Tri-Color Ink Cartridge | In Stock | £42.08 |
HP 62 2-pack Black/Tri-color Original Ink Cartridges | In Stock | £35.24 |
HP 62XL High Yield - Black - Original - Ink Cartridge | In Stock | £41.01 |
