HP Multi-Tablet Charging Module
Quicklinx: 8RSYWS00 Mfr#: H4W98AA#ABU
Say goodbye to stacks of tablets and a sea of power cords. Quickly and easily charge, update, store, and secure up to 10 tablet PCs inside the HP Tablet Charging Module so they're ready when you need them.
HP Multi-Tablet Charging Module - tablet charging module - 65 Watt
Tablet charging module - external
14.1 kg
English / United Kingdom
Power Capacity
65 Watt
46 cm x 55.15 cm x 31.66 cm
3-year warranty
ElitePad 900 G1; ENVY x2; Pro Tablet 10 EE G1
Power Capacity
65 Watt
Power cable 1.8 m
Lockable front door, built-in 2 cooling fans, rear ventilation panel, perforated front doors
EN55022, EN55024, RoHS, UL 60950-1, IEC 60950-1, KCC, WEEE, FCC Part 15 A, GOST-R, REACH, CAN/CSA C22.2 No. 60950, ICES-003 issue 4 Class A
Limited warranty - 3 years
30 °C
10 - 90% (non-condensing)
46 cm
55.15 cm
31.66 cm
14.1 kg
Shipping Width
54.5 cm
Shipping Depth
64.5 cm
Shipping Height
39 cm
Shipping Weight
17 kg
HP ElitePad 900 G1 , HP ENVY x2 11-g000ea, 11-g000eb, 11-g000ed, 11-g000eg, 11-g000eo, 11-g000ep, 11-g000es, 11-g001el, 11-g001en, 11-g001eo, 11-g001tu, 11-g005ed, 11-g010eb, 11-g010nr, 11-g016tu, 11-g030ea, 11-g033ed, 11-g040eg, 11-g050la, 11-g060ez, 11-g080ef, 11-g080el, 11-g090ef, 11-g095ca, 11-g100ef, 11-g100eg , HP Pro Tablet 10 EE G1
