StarTech.com USB-C Multiport Adapter 4K60Hz
Quicklinx: GXJPWS00 Mfr#: DKT31CH2CPD3
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
15 In Stock
£12.98 ex VAT
£15.57 inc VAT
6-IN-1 USB-C MULTIPORT ADAPTER: Features 4K 60Hz HDMI (HDR), 2x USB-C 3.2 Gen 2 (10Gbps), 1x USB-A 3.2 Gen 2 (10Gbps), Gigabit Ethernet, and a USB-C Port for 100W USB-C Power Delivery 3.0 Pass-Through - 4K 30Hz on DP 1.2 Alt-Mode hosts.
USB 3.2 GEN 2 HUB PLUS CHARGING: This USB-C Docking Station's 3-port 10 Gbps hub w/ charging has 2x USB-C ports and 1x USB-A port (high draw devices may require more power) - Connect a USB-C power adapter to enable device charging without host connection.
BUILT-IN CABLE: USB-C Mini Dock with 12" (30 cm) attached cable extends reach to reduce port/connector strain on 2-in-1 devices: Surface Pro 7/iPad Pro/HP Elite x2/laptops on riser stands - Hideaway cable management feature hides cable during travel.
RELIABLE PERFORMANCE: USB bus powered or via external USB-C power adapter - 100W Power Delivery 3.0 pass through w/ 15W reserved for adapter to avoid video flickering, device dropouts or overdrawing power common in other hubs - up to 85W for host charging.
COMPATIBILITY: Mini dock is compatible with USB-C laptops, Ultrabooks, Chromebooks, USB4 and Thunderbolt 3/4 laptops from HP, Dell, Lenovo, MacBooks (Intel & M1 Pro/Max processors) and Surface - Works w/ Windows, macOS, iPadOS, Android, Linux & Chrome OS.
PORTABLE & COMPACT: Portable USB Type-C laptop docking station with wraparound cable is designed for transport in a laptop bag, convenient for on-the-go use between office, home office, shared office spaces, and business travel.
  • Enhance Productivity
    The portable docking station provides 4K 60Hz HDMI video output, two USB 3.2 Gen 2 Type-C (10Gbps) ports, one USB 3.2 Gen 2 Type-A (10Gbps) port, and a Gigabit Ethernet port (PXE and WoL support) all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. A USB-C DisplayPort 1.4 Alt-Mode port is required for 4K 60Hz HDMI output.
  • Connect and Charge Your USB Devices
    The USB hub features two USB-C (10Gbps) ports and one USB-A (10Gbps) port for connecting up to three USB peripherals. The USB PD pass-through port enables charging of the host laptop. USB PD is only available when a USB-C power adapter is connected to the PD pass-through port. Connect a USB-C Power Adapter to use as a standalone USB peripheral charger. The extra-long attached 12inch (30cm) USB-C host cable enables an extended reach for setup flexibility.
  • Portable Connectivity
    For use while travelling, the USB-C adapter can operate bus-powered alone, or with a USB-C power adapter to enable laptop and peripheral charging. The docking station is lightweight and features a built-in wraparound USB-C host cable.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • Mac Address Pass-Through Utility: To improve network security. • USB Event Monitoring Utility: To track and log connected USB devices • Wi-Fi Auto Switch Utility: Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB-C Multiport Adapter, 4K 60Hz HDMI 2.0b, HDR, USB 3.2 Gen 2 10Gbps Hub (2xUSB-C, 1xUSB-A), 100W PD Pass-Through, Mini Travel Dock, 12"/30cm Cable, Laptop Docking Station - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 / Thunderbolt 4 - HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
HDMI
6.5 cm x 12.5 cm x 2.5 cm
98 g
Space grey
Gigabit Ethernet
Power adapter 15 Watt Power Provided
3-year warranty
Docking station
6.5 cm
12.5 cm
2.5 cm
98 g
Enclosure Colour
Space grey
Video
Max Resolution Details
3840 x 2160 - 60 Hz
USB 3.2 Gen 2
1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x USB 3.2 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 2 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C (power only) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C 3.2 Gen 2 cable - integrated - 30 cm
Up to 10Gbps data transfer, Preboot Execution Environment (PXE) support, full duplex support, plastic housing, 100W power delivery (pass-through), wake on LAN, HDR10 support
DisplayPort 1.4, USB Power Delivery 3.0, UASP (USB Attached SCSI Protocol), FCC, RoHS, WEEE
Power adapter
Power Provided
15 Watt
Apple macOS 10.15, Apple macOS 11.0, Microsoft Windows 10 / 11, Apple macOS 12.0, Apple macOS 13.0, Apple iPadOS, Android, Linux Kernel 4.x or later, Linux LTS versions only, Google Chrome OS
Limited warranty - 3 years
Shipping Width
14.3 cm
Shipping Depth
17.2 cm
Shipping Height
3 cm
Shipping Weight
166 g
50 °C
GXJP StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
GXJP StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.49
GXJP StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £21.31
GXJP StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
GXJP StarTech.com 6ft USB C Cable 5Gbps Gen1 In Stock £12.49
Device Type: Laptop
Colour: Space grey
