HP MSA2012SA SC MOD SMART ARRAY
Quicklinx: 71GDWS00 Mfr#: AJ752A
The HP StorageWorks 2000sa Modular Smart Array (MSA2000sa) is a direct attach, external shared storage solution that helps customers easily transition from direct attached to centralized storage. The ideal customers needing to consolidate their storage include smaller companies with tight budgets and limited IT expertise, or larger companies with perhaps hundreds of smaller departments and remote locations. The MSA2000sa comes standard with twelve drive bays able to simultaneously accommodate 3.5-inch enterprise-class, dual-ported SAS drives and archival-class SATA drives. Additional capacity can easily be added by attaching up to three MSA2000 12-bay drive enclosures. Maximum raw capacity ranges from 5.4 TB SAS or 12 TB SATA in the base cabinet, to over 21.6 TB SAS or 48 TB SATA with the addition of the three drive enclosures. The MSA2000 family of arrays are cost efficient in that there are never additional hidden charges, licenses or fees as you add enclosures, hosts and users.
HPE StorageWorks Modular Smart Array 2012sa Single Controller - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
SAS
Maximum LUNs
256
0 (installed) / 12 (max)
Supported Drives
SATA-300 / SAS
Storage Controller
RAID (SATA 3Gb/s / SAS) - RAID 0, 1, 3, 5, 6, 10, 50
Hard Drive
SATA 3Gb/s / SAS
Red Hat Linux 5.0, SuSE Linux 10.0, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows 2003, Microsoft Windows 2003 R2, VMware ESX Server
Power Redundancy
44.7 cm x 60.2 cm x 8.9 cm
20 kg
3-year warranty
ProLiant DL320 G5p, DL360 G5, DL360 G6, DL360 G7, DL365 G5, DL380 G5, DL380 G6, DL385 G5, DL385 G5p, DL385 G6, DL585 G5, DL585 G6, DL785 G5, DL785 G6, ML310 G5, ML310 G5p, ML330 G6, ML350 G6; StorageWorks Network Storage Gateway X3400, X3800; StorageWorks Network Storage System X3410, X3420, X3820
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SATA-300 / SAS
Storage
HDD Array External Interface
SAS
Maximum LUNs
256
CPU
Celeron 566 MHz
Storage Controller
RAID
Interface Type
SATA 3Gb/s / SAS
Data Transfer Rate
300 MBps
Cache / Buffer Size (Max)
1 GB
Supported Devices
Disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
Interface Type
SATA 3Gb/s / SAS
Expansion Bays
12 (total) / 12 (free) - 3.5"
2 x SAS , 1 x management - RJ-45
CISPR 22 Class A, CISPR 24, EN55022, EN55024, ICES-003 Class A, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC CFR47
Power Redundancy
Power Redundancy Scheme
1+1
44.7 cm
60.2 cm
8.9 cm
20 kg
Limited warranty - parts - 3 years
HPE ProLiant DL320 G5p, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 High Efficiency, DL360 G5 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL365 G5, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Efficiency, DL380 G5 High Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p, DL385 G5p Base, DL385 G5p Entry, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, DL585 G5, DL585 G5 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML310 G5, ML310 G5p, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance , HPE StorageWorks Network Storage Gateway X3400, X3800 , HPE StorageWorks Network Storage System X3410, X3420, X3820
