HP LP2065 20.1" 1600 x 1200 8ms DVI-I LCD Monitor
Customer rating: 4.0* (Write a review)
Quicklinx: 41KDWS00 Mfr#: EF227AT#ABU
Outstanding visual clarity for graphic intensive users demanding top-end features and performance.
HP LP2065 - LCD monitor - 20.1" - Smart Buy
LCD monitor - 20.1"
USB Hub
Native Resolution
1600 x 1200 at 75 Hz
Pixel Pitch
0.255 mm
Brightness
300 cd/m²
Contrast Ratio
800:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
2xDVI-I
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, anti-static
Voltage
44.3 cm x 22 cm x 42.5 cm
9.2 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, MPR II, CSA, UL, TUV, VCCI, BSMI, PC 99, GS, ISO 13406-2, NOM, CCC, TUV Ergo, MIC, FCC
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
20.1"
Built-in Devices
USB Hub
Native Resolution
Pixel Pitch
0.255 mm
Brightness
300 cd/m²
Contrast Ratio
800:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
85 Hz
Horizontal Refresh Rate
94 kHz
Video Bandwidth
202 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast, input select, colour temperature, phase, clock
9.2 kg
2 x DVI-I - 24+5 pin combined DVI , 4 x USB 2.0 downstream - 4 pin USB Type A , 1 x USB 2.0 upstream
Mechanical
VESA Mounting Interface
100 x 100 mm
2 x DVI-VGA cable - VGA to DVI-I , 2 x DVI cable - DVI-D to DVI-I
Backlight Life
45,000 hours
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
HP Smart Buy
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
55 Watt
Power Consumption Stand by / Sleep
2 Watt
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years - on-site
10 °C
35 °C
20 - 80%
Resources
The following resources are available for the HP LP2065 20.1" 1600 x 1200 8ms DVI-I LCD Monitor
Customer reviews
Write a review for the HP LP2065 20.1" 1600 x 1200 8ms DVI-I LCD Monitor here!
HP LP2065
Reviewed by Anonymous Review Posted 20/07/2007
Awesome display. Easy to setup. All cables provided. Perfect for digital photos, spreadsheets etc.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
An excellent monitor
Reviewed by Adrian. Review Posted 23/03/2007
Well I can't fault the monitor - very well built and as far as I can see a perfect picture. I am using this with my laptop which normally has a 1200*900 display (Tosbiba A100) and it drives the 1600*1200 just perfectly.
The integrated USB hub means I can have keyboard, mouse and headset all plugged to the monitor so only have to connect one USB cable to the laptop. I would have prefered all the USB ports to be in the same place to keep the cable tidier - but that is a very very small price for usch a brilliant product. And with £50 back from HP - I can't complaign.
Only gripe is the speaker panel add-on. This plugs into the USB for power only, but need to be connected to the headphone socket on the PC/Laptop - so it is not really a USB device as far as I can tell.
  • Overall 5*
  • Ease of use 5*
reasonable monitor
Reviewed by Anonymous Review Posted 19/01/2007
Pros: solid, good base, useful usb ports, reasonable quality for price
Cons: I would like some figure quoted to show monitor display uniformity. This is monitor is ok but not great for medical images.
Also better QA software would be welcomed, I dont like the autoadjust of the supplied Hp display assistant. Or maybe it doesnt support my ATI 1900 card well?
  • Overall 4*
  • Ease of use 5*
  • Value for money 4*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
