Keep things simple with an affordable HP LaserJet Pro powered by JetIntelligence Toner cartridges. Produce professional documents from a range of mobile devices, and help save energy with a compact laser printer designed for efficiency.
Designed for efficiency
- Wait less with an HP LaserJet Pro that prints faster than its predecessor6—up to 23 pages per minute.
- Grab the documents you need and go. Print first pages in as fast as 7.3 seconds.
- Help save energy with HP Auto-On/Auto-Off Technology.
Mobile printing made simple
- Print from iPhone® and iPad® with AirPrint® 1.5, which automatically scales jobs to the correct paper size.
- Print with the ease of sending an email, right from a smartphone, tablet, or notebook, using HP ePrint.
- Print directly from your mobile device to your Wi-Fi Direct® printer—without accessing the company network.
- Send jobs from your smartphone, tablet, or PC to any company printer, using Google Cloud Print™ 2.0.
HP quality—print after print
- Produce sharp text, bold blacks, and crisp graphics with precision black toner.
- Don’t be fooled by alternatives that mimic Original HP. Help ensure you’re getting the quality you paid for.
- Track toner levels with print gauge technology9—produce the most prints possible and get what you paid for.
- No delays or mess—quickly replace your cartridges, using auto seal removal and easy-open packaging
Wait less with an HP LaserJet Pro that prints faster than its predecessor – up to 22 pages per minute.Grab the documents you need and go. Print first pages in as fast as 7.3 seconds.Help save energy with HP Auto-On/Auto-Off Technology and Instant-on Technology. -
Mobile printing made simple with the HP LaserJet Pro M102w
Print from iPhone and iPad with AirPrint , which automatically scales jobs to the correct paper size.Print with the ease of sending an email, right from a smartphone, tablet, or notebook, using HP ePrint.Print directly from your mobile device to your Wi-Fi Direct printer – without accessing the company network.Send jobs from your smartphone, tablet, or PC to any company printer, using Google Cloud Print 2.0. -
HP quality – print after print
Produce sharp text, bold blacks, and crisp graphics with precision black toner.Track toner levels with print gauge technology and produce the most prints possible.Quickly replace your cartridges, using auto seal removal and easy-open packaging.
- HP LaserJet Pro M102w - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 4.7 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 22 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Interface
- USB 2.0, Wi-Fi
- AirPrint Enabled
- Processor
- 600 MHz
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCLm, URF, PWG
- Media Type
- Envelopes, labels, plain paper, photo paper, card stock, vellum paper
- Total Media Capacity
- 160 sheets
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 150 - 1500 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows Vista (32-bit versions), Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
- Environmental Standards
- EPEAT Silver
- 36.47 cm x 24.73 cm x 19.06 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi
- AirPrint Enabled
- 1200 dpi
- First Print Out Time B/W
- 7.3 sec
- PCLm, URF, PWG
- Processor
- 600 MHz
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm
- Media Weight
- 60 g/m² - 163 g/m²
- 160 sheets
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 10000 pages
- 150 - 1500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP
- Apple Bonjour, Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 380 Watt
- Power Consumption Stand by
- 1.7 Watt
- Power Consumption Sleep
- 0.5 Watt
- Software Included
- Drivers & Utilities
- OS Required
- EPEAT Compliant
- EPEAT Silver
- Blue Angel
- ENERGY STAR
- 15 °C
- 32.5 °C
- 30 - 70% (non-condensing)
- Sound Emission (Operating)
- 51 dBA
- 36.47 cm
- 24.73 cm
- 19.06 cm
- 4.7 kg
- Width (Shipping)
- 39.7 cm
- Depth (Shipping)
- 24.7 cm
- Height (Shipping)
- 19.8 cm
- Weight (Shipping)
- 6.6 kg
Ink (3)
HP 17A Black original LaserJet toner cartridge | In Stock | £54.30 |
HP 19A Original LaserJet Imaging Drum | In Stock | £61.18 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
