Expect workgroup productivity to rise with this powerful MFP that helps streamline workflow and business processes. In addition to print, copy, fax and multiple send-to functions, users can rely on advanced paper handling and finishing features.
Efficient connectivity
With both LAN and USB 2.0 interfaces, this HP LaserJet M4345 MFP ensures versatile connectivity options for seamless integration into existing networks. Its support for various network protocols including AppleTalk, DLC/LLC, and IPX/SPX enhances its compatibility across different network environments. -
High-quality copying
Achieve high-quality copying with a maximum resolution of 600 x 600 DPI. The device offers a wide range of document handling capabilities, including a maximum document enlargement of 400% and reduction of 25%, catering to all copying needs. -
Robust media handling
Designed to support a variety of media types and sizes, from envelopes and labels to plain and recycled paper. It boasts a maximum media capacity of 2100 sheets, ensuring efficient handling of large print jobs without the need for frequent reloads. -
Eco-friendly operation
This printer is both ENERGY STAR certified and Blue Angel compliant, reflecting its energy efficiency and environmentally friendly design. It combines high performance with sustainable operation. -
Advanced printing technology
Equipped with HP FastRes 1200 image enhancement technology and a maximum resolution of 1200 x 1200 DPI for printing, it delivers sharp, clear prints. Supports various printer drivers/emulations, including PCL 5e, PCL 6, PDF 1.4, and PostScript 3, offering flexibility in printing options.
- HP LaserJet M4345 MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 200000 impressions
- Max Copying Speed
- Up to 43 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 43 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 500 sheets
- Stacker
- Optional
- Stapler
- Optional
- Automatic Duplexing
- Optional (copying)
- Connection Availability
- Interface
- USB 2.0, LAN
- 76.2 cm x 48.3 cm x 54.5 cm
- 51.6 kg
- Microsoft Certification
- Certified for Windows Vista
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Copier Type
- Digital
- Laser - monochrome
- Interface
- USB 2.0, LAN
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 512 MB 512 MB
- Hard Disk Drive
- 40 GB
Copying
- Max Copying Speed
- Up to 43 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 1000
- Optional
Printing
- Up to 43 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF 1.4
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 10 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 30-bit
Document & Media Handling
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- 600 sheets
- 2100 sheets
- 500 sheets
- ADF - 50 sheets , Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Input tray - 500 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Output tray - 500 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 43 ppm (A4) , Copying: up to 43 ppm (A4)
Finishing Equipment
- Stacker
- Optional
- Stapler
- Optional
- 1 x USB 2.0 , 1 x LAN
- Network Protocols
- IPX/SPX, AppleTalk, DLC/LLC
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple MacOS X 10.2 or later, MS Windows XP Professional x64 Edition
- 1265 Watt
- Power Consumption Standby
- 280 Watt
- Power Consumption Sleep
- 24 Watt
- Consumables Included
- 1 x toner cartridge (black)
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- ENERGY STAR Certified
- Blue Angel Compliant
- 76.2 cm
- 48.3 cm
- 54.5 cm
- 51.6 kg
- Shipping Width
- 80.2 cm
- Shipping Depth
- 71.5 cm
- Shipping Height
- 64.8 cm
- Shipping Weight
- 62.1 kg
- Sound Emission
- 56 dBA (operating)
- 10 °C
- 32 °C
- 10 - 80%
