Drive business results and produce outstanding print quality. Tackle large jobs and equip workgroups for success – wherever business leads. Easily manage and expand this ultra-fast, versatile printer and help reduce environmental impact.
- HP LaserJet Enterprise M606x - printer - monochrome - laser
- Printer Type
- Workgroup printer - laser - monochrome
- 32.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 65 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 41 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 43 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ImageRet 3600 / HP ProRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), NFC, USB 2.0 host
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (1.5 GB) - SDRAM - DIMM 90-pin
- Flash Memory Installed (Max)
- 4 GB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, light-weight paper, punched paper, preprinted paper
- Total Media Capacity
- 1100 sheets
- Media Handling
- 2x 500-sheet input trays, 100-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 275000 pages
- Recommended Monthly Volume
- 5000 - 20000 pages
- Networking
- Print server
- Printer Features
- Hardware integration pocket, Instant-on Technology
- Power
- AC 230V
- System Requirements
- UNIX, Microsoft Windows XP SP3, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Windows 8 (32/64 bits), openSUSE 12.2, Apple MacOS X 10.8, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x
- 42.5 cm x 53.7 cm x 52.1 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- 4.3 inch LCD touch screen
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 7 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 1.5 GB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Flash Memory
- Flash Memory
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, 215.9 x 330.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 1100 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , 2 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 3600 sheets
- Output Trays Capacity
- 600 sheets
Duty Cycle
- 275000 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP
- Kerberos, LDAP, Apple Bonjour, IPsec, 802.1x, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 10500 pages ISO/IEC 19752
- FCC Class A certified, UL, cUL, GS, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 62479:2010, EN55024:2010, EMC 2004/108/EC, IEC 60950-1:2005, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, ICES-003 issue 4, EN 55022:2010 Class A, CISPR 22:2008
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 840 Watt
- Power Consumption Sleep
- 3.7 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 15 °C
- 32 °C
- 10 - 80%
- Sound Emission (Idle)
- 27 dBA
- Sound Emission (Operating)
- 56 dBA
- 42.5 cm
- 53.7 cm
- 52.1 cm
- 32.5 kg
- Width (Shipping)
- 75 cm
- Depth (Shipping)
- 58.9 cm
- Height (Shipping)
- 49.9 cm
- Weight (Shipping)
- 38.4 kg
