HP LaserJet Pro 4002dn Printer
Quicklinx: H7QVWS00 Mfr#: 2Z605F#B19
Get blazing fast printing speeds and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Large workteam solution
    Support your dynamic workteam with this high-speed printer, ideal for up to 10 users.
  • HP Pro-class print speed
    Step up your workflow. HP Pro-class print speed reaches up to 42 ppm to meet high-demand environments.
  • HP Smart
    Get productivity in the palm of your hand. Print and save time with Shortcuts from HP Smart.
  • HP Web Jetadmin
    Centralise your print management. HP Web Jetadmin makes it easy with its suite of features.
HP LaserJet Pro 4002dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
Number of Users
Up to 10 users
8.56 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 42 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 63 ppm - black landscape - A5 (148 x 210 mm) , Up to 14 ppm - black portrait - A5 (148 x 210 mm) , Up to 36 ipm - duplex - ANSI A (Letter) (216 x 279 mm) , Up to 34 ipm - duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 600 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN
AirPrint Enabled
1.2 GHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 6, PCL 5E, PDF, PostScript 3, PWG, URF
Media Type
Plain paper, envelopes, bond paper, coloured paper, labels, letterheaded paper, light-weight paper, preprinted paper, recycled paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
Printer Features
Instant-on Technology, JetIntelligence Cartridge Technology, Mopria certified, print from mobile device, Auto Power Off, Auto Power On
AC 220-240 V
Microsoft Windows Server, Windows 11, Windows 10, Microsoft Windows 7, Android, Apple iOS, Apple macOS 10.15, Apple macOS 11.0, Apple macOS 12, UNIX, Citrix
1-year warranty
38.1 cm x 35.7 cm x 21.6 cm
Printer Type
Workgroup printer - laser - monochrome
Number of Users
Up to 10 users
Printer
Print Speed
Built-in Devices
2 line monochrome LCD display
Wired
AirPrint Enabled
4800 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.3 sec
Language Simulation
Fonts Included
84 x TrueType
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 184 x 260 mm, 195 x 270 mm, 197 x 273 mm, B5 (176 x 250 mm), B6 (125 x 176 mm), JIS B5 (182 x 257 mm), JIS B6 (128 x 182 mm), Oficio (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 200 g/m²
Media Weight (lbs)
16 lbs - 53 lbs
350 sheets
Media Feeders
Multi-purpose tray: 1 - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 46.6 lbs (max)) , Input tray: 1 - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² - (16 lbs (min) - 32 lbs (max)) , Output tray: 1 - 150 sheets
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
750 - 4000 pages
Print server
Remote Management Protocol
HTTP, HTTPS, SNMP 1, SNMP 2, SNMP 3, IPv6, IPv4, IPP, DHCP, SLP
Security Protocols & Features
Apple Bonjour, IPv6 support, SSL
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2900 pages
CISPR 32 Class B, EN 55032:2012 Class B, CISPR 35: 2016, EN 55035 Class B, IEC 61000-3-2:2019, EN 61000-3-2:2019, EN 61000-3-3:2013+A1:2019, EN 61000-4-12, FCC CFR47 Part 15 B Class B, ICES-003 issue 7, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014, IEC 60825-1:2014, EN 60825-1:2014, IEC 62479:2010, EN 62479:2010, Mercury-free, IEEE 802.3az, IPv6, IPv4
Power supply - internal
AC 220-240 V
Frequency Required
50/60 Hz
495 watt
Power Consumption Stand by
5.5 watt
Power Consumption Sleep
0.5 watt
System Requirements Details
HD 2 GB
Environmental Standards
Blue Angel
ENERGY STAR
ENERGY STAR Version
3.0
Limited warranty - 1 year
10 °C
32.5 °C
10 - 80% RH
Sound Emission (Operating)
54 dBA
38.1 cm
35.7 cm
21.6 cm
8.56 kg
Width (Shipping)
44.3 cm
Depth (Shipping)
27.4 cm
Height (Shipping)
46.4 cm
Weight (Shipping)
10.5 kg
Ink (2)
H7QV HP HP - Black - original - LaserJet - toner cartridge In Stock £84.97
H7QV HP 149X - high capacity - black - original - LaserJet - toner cartridge In Stock £170.99
Other bundles (1)
H7QV HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn In Stock £100.51
