HP LaserJet Enterprise M606dn Mono Laser Printer
Quicklinx: BDSSWS00 Mfr#: E6B72A#B19
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Drive business results and produce outstanding print quality. Tackle large jobs and equip workgroups for success – wherever business leads. Easily manage and expand this ultra-fast, versatile printer and help reduce environmental impact.
  • Only the power you need
    Help save energy with HP Auto-On/Auto-Off Technology.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • Prints in a flash, savings that last
    Print right away with Instant-on Technology.
HP LaserJet Enterprise M606dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
25.9 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 65 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 41 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 43 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Image Enhancement Technology
HP ImageRet 3600 / HP ProRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
1.2 GHz
RAM Installed (Max)
512 MB (1.5 GB) - SDRAM - DIMM 90-pin
Flash Memory Installed (Max)
4 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, light-weight paper, punched paper, preprinted paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
275000 pages
Recommended Monthly Volume
5000 - 20000 pages
Print server
Printer Features
Hardware integration pocket, Instant-on Technology
UNIX, Microsoft Windows XP SP3, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x
1-year warranty
42.5 cm x 53.7 cm x 39.9 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 1.5 GB (max)
Technology / Form Factor
SDRAM - DIMM 90-pin
Slots Qty
1
Empty Slots
1
Flash Memory
Flash Memory
4 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, 215.9 x 330.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
Media Weight
60 g/m² - 200 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
3600 sheets
Output Trays Capacity
600 sheets
Duty Cycle
275000 pages
5000 - 20000 pages
Print server
Network Controller Name
HP Jetdirect
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP
Security Protocols & Features
Kerberos, LDAP, Apple Bonjour, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 10500 pages
FCC Class A certified, UL, cUL, GS, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 62479:2010, EMC 2004/108/EC, IEC 60950-1:2005, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, ICES-003 issue 4, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008
Security Slot Type
Kensington security slot
Power supply - internal
Frequency Required
50/60 Hz
840 Watt
Power Consumption Sleep
3.7 Watt
Software Included
Drivers & Utilities
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year - on-site
15 °C
32 °C
10 - 80%
Sound Emission (Idle)
27 dBA
Sound Emission (Operating)
56 dBA
42.5 cm
53.7 cm
39.9 cm
25.9 kg
Width (Shipping)
62.7 cm
Depth (Shipping)
58.9 cm
Height (Shipping)
49.9 cm
Weight (Shipping)
29.3 kg
BDSS HP 81A Black Original LaserJet Toner Cartridge In Stock £150.94
BDSS HP 81X High Yield Black Original LaserJet Toner Cartridge In Stock £249.76
