Designed to support medium to large workgroups with high-volume print needs, the HP LaserJet Enterprise 600 M600 printer series delivers advances in productivity, manageability and security without compromising quality. Businesses can increase efficiency and improve document workflow processes with several management tools, including HP FutureSmart Firmware, which simplifies the process of deploying customized HP and third-party document management solutions.
The HP LaserJet Enterprise 600 M600 printer series is ENERGY STAR qualified and comes equipped with auto-on/auto-off technology - which turns the printer on when it's needed and off when it's not - and reduced sound emissions for a more tranquil work environment.
The HP LaserJet Enterprise 600 M602n is the base model and includes: print speeds of up to 52 ppm, network ready support, a four-line graphical color display, 10-number keypad, hardware integration pocket, 100-sheet multipurpose tray, 500-sheet input tray, high-speed host USB port for walk-up printing.
- Printer Type
- Workgroup printer
- Wireless Capability
- Wired
- Interface
- USB
- Printer / PostScript Support
- Standard
- Functionality
- Printer
- Networking / Type
- Print server
- Compatibility
- PC
- Scanner / Type
- None
- Output Type
- Monochrome
- Technology
- Laser
- Header / Product Line
- HP LaserJet
- Header / Manufacturer
- Hewlett-Packard
- Header / Model
- Enterprise M602n
- Max Print Speed
- 50 ppm
- Printer / Max H-Resolution B/W
- 1200 dpi
- Header / Packaged Quantity
- 1
HP 90A Black Original LaserJet Toner Cartridge | In Stock | £151.63 |
HP 90X 2-pack High Yield Black Original LaserJet Toner Cartridges | In Stock | £456.13 |
