HP Envy Photo 7830 Colour Ink-Jet
Multifunction Printer
HP Envy Photo 7830 Colour Ink-Jet Multifunction Printer
Quicklinx: F7FLWS00 Mfr#: Y0G50B#BHC
Get productive performance and photos that shine with powerful all-in-one capabilites. Produce authentic colours, and set up, connect, and print right from your mobile device.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Easy mobile printing from HP
    Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
  • Save up to 70% on ink
    Save up to 70% on ink. Original HP ink delivered to your door with HP Instant Ink.
HP ENVY Photo 7830 All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
Fax Type
Plain paper
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 13 ppm (mono) / up to 5 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 21 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 311 dpi, 196 x 208 dpi, 200 x 208 dpi, 98 x 208 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
97.8 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, photo paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
125 sheets
Max Media Capacity
125 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host, Bluetooth LE
AirPrint Enabled
Office Machine Features
Print from memory card, print from USB flash drive, scan to e-mail, HP Auto Wireless Connect, automatic paper sensor, scan to memory card, HP Instant Ink, scan to USB host, print from mobile devices
AC 120/230 V (50/60Hz)
45.35 cm x 41 cm x 19.32 cm
7.6 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
1000 pages
300 - 400 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Supported Flash Memory
SD Memory Card, USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
50
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
704 nozzles (black), 2052 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
16 sec
First Print Out Time Colour
18 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Interpolated Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Speed Dialing
120 station(s)
Broadcast Transmission
20 stations
Delayed Transmission
Yes (black only)
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
97.8 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
75 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 101.6 x 152.4 mm, 101.6 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
Borderless Photo Sizes
216 x 297 mm
125 sheets
Max Media Capacity
125 sheets
25 sheets
Input tray - 125 sheets size: 97.8 x 127 mm - Legal (216 x 356 mm) weight: 75 g/m² - 250 g/m² , Photo tray - 15 sheets , Output tray - 25 sheets
Speed Details
Printing: up to 22 ppm (A4) - B/W draft , Printing: up to 21 ppm (A4) - colour draft , Printing: up to 15 ppm (A4) - B/W normal , Printing: up to 10 ppm (A4) - colour normal , Printing: 40 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 21 ppm (A4) - B/W draft , Copying: up to 19 ppm (A4) - colour draft , Copying: up to 13 ppm (A4) - B/W (ISO) , Copying: up to 5 ppm (A4) - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
Apple Bonjour, WEP, WPA
Operating System Support
Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12
Software Included
HP Photo Creations, HP Update
13.95 Watt
Power Consumption Standby
3.6 Watt
Power Consumption Sleep
0.93 Watt
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 1 year
45.35 cm
41 cm
19.32 cm
7.6 kg
Shipping Width
49.7 cm
Shipping Depth
24.7 cm
Shipping Height
49.1 cm
Shipping Weight
9.7 kg
Sound Emission
57 dBA (operating)
5 °C
15 - 80% (non-condensing)
Ink (5)
F7FL HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.62
F7FL HP 303 Original Black Ink Cartridge In Stock £13.37
F7FL HP 303 4ml Dye-Based Tricolour Original Ink In Stock £15.97
F7FL HP 303XL High Yield Black Original Ink Cartridge In Stock £30.28
F7FL HP 303XL High Yield Tri-color Original Ink Cartridge In Stock £34.48
Other bundles (1)
F7FL HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £17.00
