HP DreamColor Z32x 31.5" 3840 x 2160 8ms HDMI LED Monitor
Quicklinx: CY4SWS00 Mfr#: M2D46A4#ABU
Go big or go home with the HP DreamColor Z32x 80,01 cm (31.5") UHD Display, HP's largest UHD 4K display, which delivers a staggering 8 million pixels and 4K resolution and has award- winning HP DreamColor technology built right in.
  • Customize your comfort
    Work comfortably with adjustable tilt, height adjustment, and swivel settings. Use pivot rotation for portrait or landscape views when using multiple displays. An integrated HP Quick Release Bracket supports wall mounting.
  • Your monitor's new best friend
    Design the screen for how you work with HP Display Assistant software.
  • Designed with the environment in mind
    Be a better consumer with a display that has environmentally responsible components.
HP DreamColor Z32x Professional - LED monitor - 4K - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.182 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort, MHL
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
73.71 cm x 24.54 cm x 61.38 cm
10.8 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, EPA, CEL Grade 1, ISC, SEPA
5-year warranty
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.182 mm
Pixel Per Inch
140
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
24 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
Picture in picture, picture by picture, HDCP, DreamColor, Mobile High-Definition Link (MHL) 2.0, Colour gamut BT.709, arsenic-free glass
73.71 cm x 24.54 cm x 61.38 cm - with stand
10.8 kg
MHL / HDMI (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , Audio line-out , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, 1 USB 3.0 charging port, low halogen
1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
40,000 hours
Security Slot Type
Kensington security slot
Input Voltage
19 W
Power Consumption (Typical)
86 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Drivers & Utilities, HP Display Assistant
Dimensions & Weight Details
With stand - width: 73.71 cm - depth: 24.55 cm - height: 61.38 cm - weight: 10.8 kg , Without stand - width: 73.71 cm - depth: 7.01 cm - height: 43.46 cm - weight: 7.8 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
