HP Mini-in-One 24" 1920x1080 5ms DisplayPort USB-C IPS LED Monitor
Quicklinx: FRPCWS00 Mfr#: 7AX23AT#ABU
Maximize your workspace with the Mini-in-One display that fully encloses a USFF PC and is purpose-built to seamlessly connect, contain, secure, and power your Mini - from this generation to the next. Multi-task like a pro in Full HD resolution, and add your USB devices at the display.
  • Large-screen views
    See more of your work at one time on the 23.8" diagonal Full HD screen with 3-sided micro-edge bezels. Connect additional displays through DisplayPort for a virtually seamless, panoramic multi-display setup.
  • Find your comfort zone
    Work comfortably with adjustable settings that include tilt, height, swivel, and pivot rotation for portrait or landscape views-even with the Mini installed.
  • Communicate clearly
    Support collaboration and web meetings without cluttering your desk with a built-in Full HD webcam, universal audio jack for your headset, and integrated stereo speakers.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions to work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
  • Responsibly made
    Energy efficiency is built into our low-halogen, ENERGY STAR certified, EPEAT Gold registered design that meets TCO Certified Edge with 85% post-consumer recycled plastics.
  • Click or call for support
    Rest assured with a three-year standard limited warranty. Extend protection with an optional HP Care service.
HP Mini-in-One 24 - LED monitor - Full HD (1080p) - 23.8" - Smart Buy
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
17.8 W
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 800000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 5 ms (overdrive)
Colour Gamut
72% NTSC
Input Connectors
DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Black, silver (stand)
53.96 cm x 24.2 cm x 50.38 cm
7.2 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93.24
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge, 72% NTSC colour gamut
53.96 cm x 24.2 cm x 50.38 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) , USB 3.1 Gen 1 upstream (Type B) , 6 x USB 3.1 Gen 1 downstream (Type A) , USB-C 3.1 Gen 1 (HDCP) , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
17.8 W
17.8 kWh/1000h
Power Consumption (Typical)
50 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.96 cm - depth: 24.2 cm - height: 50.38 cm - weight: 7.2 kg , Without stand - width: 53.96 cm - depth: 7.5 cm - height: 36.76 cm - weight: 4.06 kg
Shipping Width
65 cm
Shipping Depth
47.3 cm
Shipping Height
31.5 cm
Shipping Weight
12.78 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
FRPC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.83
FRPC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.64
FRPC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.04
FRPC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.81
