HP DesignJet Z5600PS
Quicklinx: CP0SWS00 Mfr#: T0B51A#B19
Print vivid, eye-catching graphics and technical documents with HP chromatic red ink. Multi-roll operation and flexible workflows enable express printing. HP's optimized 6-ink printing system helps reduce ink consumption up to 20%.
Produce impressive, high-impact graphics—HP chromatic red ink creates eye-catching POP signs, posters. Print a versatile range of durable, lasting applications from GIS, maps, and technical drawings to photos, canvas.
Impressive—HP chromatic red ink enhances the color gamut—ideal for high-impact POP signs and posters. Versatile—with pigment-based photo inks for GIS, durable maps, technical drawings and photos, canvas. Reliable color, line accuracy—HP Professional PANTONE® color emulation, with Adobe® PostScript®/PDF, HP-GL/2. Durable—water/scratch/fade-resistant and archivable prints last up to 200 years with HP Vivid Photo Inks.
Simple, flexible operation. Automatic multi-roll printing boosts media loading efficiency up to 75%. Print up to 39% faster with quick-drying HP inks. Enjoy easy one-click printing. PostScript® and broad RIP choice support color workflows.
Boost operator media loading efficiency up to 75% with automatic multi-roll printing. Print up to 39% faster—save time on technical drawings with quick-drying HP Vivid Photo Inks. Easy—one-click printing, color touchscreen, print preview, direct USB flash drive, email printing. Flexible—supports color workflows with genuine Adobe® PostScript® and broad choice of RIPs.
Spend less time and help reduce operating costs. HP's optimized 6-ink printing system helps you reduce ink consumption up to 20%. Less operator attention is needed with 300-ml HP ink cartridges, optimized media usage, and no maintenance cartridge.
Up to 20% ink consumption savings using HP’s optimized 6-ink printing system. No maintenance cartridge—auto drop detection and nozzle switching reduce cleaning, maintain image quality. Less operator intervention and more cost-effective printing with 300-ml HP ink cartridges. Optimize media usage by auto-arranging multiple images on a roll with HP DesignJet Click printing software.
  • Eye-catching, water/fade-resistant images
    Impressive-HP chromatic red ink enhances the color gamut-ideal for high-impact POP signs and posters.Versatile-with pigment-based photo inks for GIS, durable maps, technical drawings and photos, canvas.Reliable color, line accuracy-HP Professional PANTONE color emulation, with Adobe PostScript /PDF, HP-GL/2.Durable-water/scratch/fade-resistant and archivable prints last up to 200 years with HP Vivid Photo Inks.VIVID.
  • Fast one-click, and multi-roll
    Boost operator media loading efficiency up to 75% with automatic multi-roll printing.Print up to 39% faster-save time on technical drawings with quick-drying HP Vivid Photo Inks.Easy-one-click printing, color touchscreen, print preview, direct USB flash drive, email printing.Flexible-supports color workflows with genuine Adobe PostScript and broad choice of RIPs.EXPRESS PRINTING.
  • Cut costs with HP 6-ink printing system
    Up to 20% ink consumption savings using HP's optimized 6-ink printing system.No maintenance cartridge-auto drop detection and nozzle switching reduce cleaning, maintain image quality.Less operator intervention and more cost-effective printing with 300-ml HP ink cartridges.Optimize media usage by auto-arranging multiple images on a roll with HP DesignJet Click printing software.SAVINGS.
HP DesignJet Z5600 PostScript - large-format printer - colour - ink-jet
Printer Type
44" large-format printer - ink-jet - colour
86.5 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
6-ink - cyan, magenta, yellow, matte black, photo black, chromatic red
Max Media Size
Roll (111.8 cm x 91 m)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
1118 mm x 1676 mm
Print Speed
Up to 60 sq.m/hour , Up to 48 sq.m/hour - colour draft , Up to 7 sq.m/hour - colour best , Up to 8.9 sq.m/hour - normal
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Cutter
USB 2.0, Gigabit LAN
RAM Installed (Max)
640 MB
Hard Drive
320 GB
Language Simulation
PCL 3, PostScript 3, CALS G4, HP GL/2, PDF, TIFF, HP PCL 3 GUI
Media Type
Photo paper, fabric, fine art paper, bond paper, proofing paper, banner paper, film, backlit paper, coated paper, self-adhesive paper
Print server
1-year warranty
177 cm x 77.5 cm x 105 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
2112 nozzles
Ink Cartridge Configuration
6 individual ink tanks; 2 colours per print head
Ink Type
HP Vivid Photo Inks
Print Speed
Wired
2400 x 1200 dpi
2400 x 1200 dpi
PostScript Support
Standard
Language Simulation
Cutter
Colour Management Features
PANTONE Digital Color
RAM
RAM Installed (Max)
640 MB
Storage
Hard Drive
320 GB
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
1118 mm x 1676 mm
Media Sizes
Roll (111.8 cm x 91 m), 210 x 279 mm, 1118 x 1676 mm
Media Weight
80 g/m² - 500 g/m²
Media Feeders
1 x manual - 1 roll - Roll (111.8 cm x 91 m) weight: 80 g/m² - 500 g/m²
Print server
Expansion Slots
1 x EIO
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
Spindle, stand
Consumables Included
6 x ink cartridge , 3 x printhead
FCC Class A certified, CSA, GOST, CCC, PSB, IRAM, RoHS, EN 60950-1, KCC, WEEE, REACH, ICES Class A, LVD, EMC Class A, VCCI Class A
Power supply - internal
Frequency Required
50/60 Hz
120 Watt
Power Consumption Stand by
32 Watt
Power Consumption Sleep
1.5 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
5 °C
20 - 80%
Sound Emission (Idle)
22 dBA
Sound Emission (Operating)
42 dBA
177 cm
77.5 cm
105 cm
86.5 kg
Width (Shipping)
193 cm
Depth (Shipping)
77 cm
Height (Shipping)
72 cm
Weight (Shipping)
119.5 kg
