HP DesignJet Z3200PS 24" A1 Large Format Printer
YOU BUY. YOU TRY. YOU DECIDE!
Quicklinx: 85SJWS00 Mfr#: Q6720B#B19
This 12-ink HP Designjet, with new HP 73 Chromatic Red ink, delivers long-lasting gallery-quality prints in black-and-white and colour. HP DreamColor Technologies with an embedded spectrophotometer enable easy calibration and profiling.
  • Wide color gamut and outstanding black-and-white
    12 Original HP Photo Inks deliver gallery-quality black-and-white and color prints lasting up to 200 years.Create exceptional black-and-white prints-an HP Quad-black ink set delivers smooth transitions, neutral grays.Get superior gloss uniformity and minimize bronzing on most glossy photo papers with HP Gloss Enhancer.Achieve an expanded color gamut with 96% PANTONE coverage enabled by HP chromatic red ink.
  • Easy color calibration and profiling
    Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer.See consistent print-to-print color regardless of fluctuating environmental conditions with HP technologies.Simplify your workflow- easily access, create, and share paper presets using the enhanced HP Color Center.Get color reliability with HP Professional PANTONE color emulation and Adobe Postscript /PDF support.
  • Low-maintenance and high ink efficiency
    Optimize performance, ink usage-automatic servicing routines help prevent nozzle clogging, reduce media waste.Save time, money-embedded TIFF, JPEG, and Adobe PS3/PDF RIP enable direct job submission, queuing, nesting.Streamline production with an HP Embedded Web Server and print previews, which help eliminate trial and error.Stay up-to-date-HP Printer Utility software provides printer status, desktop alerts, and automatic updates.
HP DesignJet Z3200ps - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
65 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
12-ink
Max Media Size
Roll A1 (61.0 cm), Roll ARCH D (61 cm)
Min Media Size (Custom)
216 mm x 279 mm
Max Media Size (Custom)
610 mm x 1676 mm
Print Speed
Up to 2 min/page - colour fast - A1 (594 x 841 mm) , Up to 12.4 min/page - colour best - A1 (594 x 841 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB, Gigabit LAN
RAM Installed (Max)
256 MB
Hard Drive
80 GB
Language Simulation
PCL 3, PostScript 3, TIFF, PDF 1.6
Media Type
Photo paper, fabric, fine art paper, proofing paper, banner paper, film, backlit paper, coated paper
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.4, Apple MacOS X 10.6, Apple MacOS X 10.5, Citrix MetaFrame, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
Microsoft Certification
Compatible with Windows 7
126 cm x 69 cm x 105 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
12-ink
Nozzle Configuration
12 x 1056 nozzles
Minimum Ink Droplet Size
4 pl
Ink Cartridge Configuration
12 individual ink tanks; 2 colours per print head
Ink Type
HP Vivera Inks
Print Speed
Wired
USB, Gigabit LAN
2400 x 1200 dpi
2400 x 1200 dpi
PostScript Support
Standard
Language Simulation
RAM
RAM Installed (Max)
256 MB
Storage
Hard Drive
80 GB
Media Handling
Media Type
Max Media Size
216 mm x 279 mm
610 mm x 1676 mm
Media Thickness Range
Up to 0.8 mm
Media Weight
500 g/m²
Media Feeders
1 x manual - 1 roll - Roll A1 (61.0 cm)
Print server
Expansion Slots
1 x EIO
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
Spindle, stand
1 x USB cable
Consumables Included
1 x ink cartridge (light cyan) , 1 x ink cartridge (light magenta) , 1 x ink cartridge (light grey) , 1 x ink cartridge (photo black) , 1 x ink cartridge (grey) , 1 x ink cartridge (gloss enhancer) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (matte black) , 1 x ink cartridge (chromatic red) , 1 x ink cartridge (green) , 1 x ink cartridge (blue) , 6 x printhead
CSA, VCCI, BSMI, GOST, CCIB, CCC, EMC, DOC, PSB, MIC, MOC, FCC, IRAM, IEC 60950-1, EN 60950-1, ACA, LVD
Power supply - internal
Frequency Required
50/60 Hz
200 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Idle)
29 dBA
Sound Emission (Operating)
49 dBA
126 cm
69 cm
105 cm
65 kg
Width (Shipping)
147 cm
Depth (Shipping)
78 cm
Height (Shipping)
74 cm
Weight (Shipping)
102 kg
85SJ HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) In Stock £11.37
85SJ HP Special Inkjet Paper-610 mm x 45.7 m (24in x 150ft) In Stock £65.89
