Save space, time, and money with a compact plotter with built-in Wi-Fi that lets you print right away. Speed up the PDF printing process. Print from your smartphone with the HP Smart app. Get high quality and high speed.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
- HP DesignJet T130 - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 25.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Max Media Size
- Roll A1 (61.0 cm x 45.7 m)
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 610 mm x 45.7 m
- Print Speed
- Up to 0.58 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - black draft - A1 (594 x 841 mm) , Up to 0.58 min/page - colour draft - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Cutter
- Interface
- USB 2.0, LAN, Wi-Fi
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- HP GL/2, JPEG
- Media Type
- Plain paper, photo paper, bond paper, recycled paper, film, glossy paper
- Networking
- Print server
- Printer Features
- 4.1 kg max roll weight
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows Vista Business (32/64 bits), Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows Vista Ultimate (32/64 bits), Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows XP Home Edition x64 Edition SP3, Apple OS X 10.8 Mountain Lion, Citrix XenServer, Citrix XenApp, Microsoft Windows XP Home Edition SP3 (32-bit), Microsoft Windows XP Professional SP3 (32/64 bits)
- 2-year warranty
- 98.7 cm x 53 cm x 28.5 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1376 nozzles
- Minimum Ink Droplet Size
- 12 pl (black), 5.5 pl (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, pigment black)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- HP GL/2, JPEG
- Cutter
- Printer Features
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 610 mm x 45.7 m
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A1 (594 x 841 mm), ANSI D (559 x 864 mm), Roll (61 cm x 45.7 m)
- Media Thickness Range
- Up to 0.3 mm
- Media Weight
- 60 g/m² - 280 g/m²
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- R&TTE, RoHS, EN 60950-1, WEEE, REACH, LVD, EuP, EMC Class B
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 35 Watt
- Power Consumption Stand by
- 6 Watt
- Power Consumption Sleep
- 4.5 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 45 dBA
- 98.7 cm
- 53 cm
- 28.5 cm
- 25.5 kg
- Width (Shipping)
- 114.1 cm
- Depth (Shipping)
- 62 cm
- Height (Shipping)
- 41.5 cm
- Weight (Shipping)
- 30 kg
Ink (9)
HP 711 3-pack 29-ml Cyan Ink Cartridges | In Stock | £55.96 |
HP 711 3-pack 29-ml Magenta Ink Cartridges | In Stock | £55.96 |
HP 711 3-pack 29-ml Yellow Ink Cartridges | In Stock | £55.96 |
HP 711 80-ml Black Ink Cartridge | In Stock | £49.14 |
HP 711 29-ml Cyan Ink Cartridge | In Stock | £24.70 |
HP 711 29-ml Magenta Ink Cartridge | In Stock | £24.70 |
HP 711 29-ml Yellow Ink Cartridge | In Stock | £24.70 |
HP 711 Designjet Printhead Replacement Kit | In Stock | £183.98 |
HP 711 38-ml Black Ink Cartridge | In Stock | £29.84 |
Other bundles (2)
HP Designjet T120/T520 24" Spindle | In Stock | £45.80 |
HP Care Pack Installation Service - Installation / Configuration | In Stock | £375.11 |
