HP 711 38-ml Black Ink Cartridge
Quicklinx: 93BZWS00 Mfr#: CZ129A
Type: Ink Cartridge
Technology: [N/A]
£34.08 ex VAT
£40.89 inc VAT
HP 711 38-ml Black Ink Cartridge provides consistent, accurate results. See sharp line accuracy in fast-drying, smudge-resistant prints. Original HP inks are designed and tested with your printer to provide consistent results.
  • Trial and error costs you time. To get the consistent quality you need, look to Original HP supplies designed with your printer as an optimised printing system to provide accurate lines, sharp detail and rich colour quality
    See consistent quality-ultra-pure Original HP inks are designed with your printer for sharp, accurate results.
  • Choose the size to fit your needs and your budget whether you print a little or a lot. Choose from 38-ml black cartridges to print in low print volume or 80-ml black for high volume
    Fit 29-ml color, 38-ml black cartridges to low print volume or 80-ml black, color 3-packs to high volume.
  • Imagine the impact you can make with clear, easily readable drawings and colourful, powerful presentations. Original HP inks deliver a unique combination of quality and resilience - see sharp lines in fast-drying, smudge-resistant prints
    See sharp lines to 0.02 mm (0.0008 inch) minimum line width enabled by Original HP inks and your printer.
HP 711 - black - original - DesignJet - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Printing Colour
Black (pigmented)
38 ml
Compatible with
DesignJet T100, T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
Dimensions (WxDxH) / Weight
90 g
Shipping Width
11.9 cm
Shipping Depth
12.6 cm
Shipping Height
3.6 cm
Shipping Weight
110 g
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Black (pigmented)
Included Qty
1-pack
38 ml
Compatible with
HP DesignJet T100, T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
Type: Ink Cartridge
Technology: [N/A]
Brand: HP
