HP DesignJet T130 24" Thermal InkJet Large Format Printer
Quicklinx: FGQNWS00 Mfr#: 5ZY58A#B19
Save space, time, and money with a compact plotter with built-in Wi-Fi that lets you print right away. Speed up the PDF printing process. Print from your smartphone with the HP Smart app. Get high quality and high speed.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
HP DesignJet T130 - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
25.5 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Max Media Size
Roll A1 (61.0 cm x 45.7 m)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
610 mm x 45.7 m
Print Speed
Up to 0.58 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - black draft - A1 (594 x 841 mm) , Up to 0.58 min/page - colour draft - A1 (594 x 841 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Cutter
USB 2.0, LAN, Wi-Fi
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
HP GL/2, JPEG
Media Type
Plain paper, photo paper, bond paper, recycled paper, film, glossy paper
Print server
Printer Features
4.1 kg max roll weight
Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows Vista Business (32/64 bits), Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows Vista Ultimate (32/64 bits), Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows XP Home Edition x64 Edition SP3, Apple OS X 10.8 Mountain Lion, Citrix XenServer, Citrix XenApp, Microsoft Windows XP Home Edition SP3 (32-bit), Microsoft Windows XP Professional SP3 (32/64 bits)
98.7 cm x 53 cm x 28.5 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1376 nozzles
Minimum Ink Droplet Size
12 pl (black), 5.5 pl (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, pigment black)
Print Speed
Wireless
USB 2.0, LAN, Wi-Fi
1200 x 1200 dpi
1200 x 1200 dpi
Language Simulation
HP GL/2, JPEG
Cutter
Printer Features
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
610 mm x 45.7 m
Media Sizes
ANSI A (Letter) (216 x 279 mm), A1 (594 x 841 mm), ANSI D (559 x 864 mm), Roll (61 cm x 45.7 m)
Media Thickness Range
Up to 0.3 mm
Media Weight
60 g/m² - 280 g/m²
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
R&TTE, RoHS, EN 60950-1, WEEE, REACH, LVD, EuP, EMC Class B
Power supply - internal
Frequency Required
50/60 Hz
35 Watt
Power Consumption Stand by
6 Watt
Power Consumption Sleep
4.5 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
45 dBA
98.7 cm
53 cm
28.5 cm
25.5 kg
Width (Shipping)
114.1 cm
Depth (Shipping)
62 cm
Height (Shipping)
41.5 cm
Weight (Shipping)
30 kg
Ink (9)
FGQN HP 711 3-pack 29-ml Cyan Ink Cartridges In Stock £64.49
FGQN HP 711 3-pack 29-ml Magenta Ink Cartridges In Stock £61.47
FGQN HP 711 3-pack 29-ml Yellow Ink Cartridges In Stock £64.49
FGQN HP 711 80-ml Black Ink Cartridge In Stock £55.29
FGQN HP 711 29-ml Cyan Ink Cartridge In Stock £28.19
FGQN HP 711 29-ml Magenta Ink Cartridge In Stock £29.67
FGQN HP 711 29-ml Yellow Ink Cartridge In Stock £28.19
FGQN HP 711 Designjet Printhead Replacement Kit In Stock £208.68
FGQN HP 711 38-ml Black Ink Cartridge In Stock £34.08
Other bundles (2)
FGQN HP Designjet T120/T520 24" Spindle In Stock £46.47
FGQN HP Care Pack Installation Service - Installation / Configuration In Stock £377.00
