HP Designjet HD Scanner
Quicklinx: 9HFTWS00 Mfr#: CQ654C#B19
Streamline your workflow and improve productivity by bringing large-format, colour scanning in-house. In fact, it complements your existing large-format printing capabilities. The outstanding scan performance of the HP Designjet Scanner helps increase efficiency, while high processing speeds allow faster scan and copy performance. A resolution of 600 dpi optical from four CCD cameras enables high-quality images with realistic colours and precise lines even when using originals of poor quality.
  • Quickly transform originals into digital documents
    See high speeds up to 7.6 cm (3 in)/sec for colour and up to 25.4 cm (10 in)/sec for black-and-white scans.Take advantage of the HP Designjet Scanner's high processing speeds to make short work of large files.Powerful scan resolution helps you to create images with realistic colours and precise lines that improve upon the original.Produce large-format colour and black-and-white scans from wide or thick, rigid originals.
  • Create an integrated HP scan-copy-print system
    Obtain consistent colour reproduction with closed-loop colour calibration.Integrate with the printer for excellent ease of use, copy quality, and performance.Build a powerful, easy-to-use, HP production system using preconfigured drivers and built-in network connectivity which make it easy to print and copy directly to your HP Designjet products.Save scanned files in a variety of file formats including PDF, TIFF, JPEG2000 and DWF and easily integrate with third-party applications.
  • Easily scan and copy at the touch of a button
    Enjoy easy and intuitive operation with an 38.1 cm (15 in) touchscreen graphical display.Use advanced copy features to streamline your job and make copies quickly and easily.Enlarge or reproduce images and adjust margins to create ideal images.Use the nesting option to save media and make large enlargements easily with the paneling option.Tap into seamless network connectivity for easy access using 1000Base-T networking and TCP/IP protocols.
HP Designjet HD Scanner - roll scanner - USB 2.0, FireWire, Gigabit LAN
Roll scanner
Interface Type
Max Supported Document Size
Roll (106.7 cm)
English, German, French, Italian, Spanish / Europe
Input Type
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Size
1067 mm
180 cm x 85 cm x 138 cm
92.5 kg
1-year warranty
DesignJet T795 ePrinter, Z6600 Production Printer, Z6800 Photo Production
Roll scanner
Interface Type
Roll (106.7 cm)
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
9600 dpi x 9600 dpi
Scanner Speed Details
80 mm / sec - colour - 200 dpi , 250 mm / sec - black & white - 200 dpi
Scanner Features
15" touch screen TFT display
Media Handling
Max Document Size
1067 mm
Gigabit LAN , USB 2.0 - Type B , FireWire
Stand
2 x IEEE 1394 cable , 1 x network cable
FCC Class A certified, CSA, GOST, VCCI Class A ITE, CCC, PSB, MOC, IRAM, RoHS, EN 60950-1, WEEE, REACH, BSMI Class A, ICES Class A, KCC Class A, LVD, EMC Class A
Internal power supply
Power Consumption Operational (Standby)
300 Watt (38.3 Watt)
Software Included
Drivers & Utilities
180 cm
85 cm
138 cm
92.5 kg
Shipping Width
191 cm
Shipping Depth
76 cm
Shipping Height
68 cm
Shipping Weight
140 kg
Limited warranty - 1 year
5 °C
20 - 80%
Sound Emission
47 dBA
HP DesignJet T795 ePrinter, Z6600 Production Printer, Z6800 Photo Production
