HP Colour LaserJet 2840 All-in-One series Printer / Fax1 / Scanner / Copier
Customer rating: 4.0* (Write a review)
Quicklinx: 3N7GWS00 Mfr#: Q3950A#ABU
Network-ready HP Color LaserJet All-in-One for printing, faxing, scanning, copying and digital imaging. Get fast, dependable black and white, and professional, high-quality colour documents with a robust design that is easy to use and maintain.
  • Maximise productivity with network-ready colour laser All-in-One versatility
    Increase productivity with integrated printing, professional faxing, scanning, copying and digital imaging functionality. This network-ready All-in-One delivers fast printing speeds, and Instant-on Technology means no wait for your documents.
  • Create impressive and effective documents with colour laser print quality
    Get vibrant colour documents with HP ImageREt 2400 technology and HP supplies which together create accurate tones, clear lines and sharp images. Use HP Photosmart Premier to view, enhance, manage and share digital photos and scanned images.
  • The integrated design of this reliable all-in-one makes it easy to use, manage and maintain
    The integrated design and intuitive control panel ensures uncomplicated operation, enabling you to get the full benefit of All-in-One functionality. User-friendly HP Smart printing supplies make colour printing easy and consistent.
HP Color LaserJet 2840 All-in-One - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 impressions
Max Copying Speed
Up to 19 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
127 x 127 mm (min) - 216 x 381 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper
Standard Media Capacity
375 sheets
Output Trays Capacity
125 sheets
Connection Availability
USB 2.0, LAN
AC 230 V (50/60Hz)
49.8 cm x 53.2 cm x 57.3 cm
34.2 kg
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
30000 impressions
USB 2.0, LAN
Standard Memory
96 MB 96 MB
Max Supported Memory
224 MB 224 MB
Supported Flash Memory
Memory Stick, CompactFlash, SmartMedia, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
Image Enhancement Technology
HP FastRes 1200
Scanning
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 250 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
120 station(s)
Document & Media Handling
Min Original Size
127 x 127 mm
Max Original Size
216 x 381 mm
Original Type
Sheets
50 sheets
Min Media Size
127 x 127 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
177 g/m²
Supported Media Type
375 sheets
125 sheets
ADF - 50 sheets size: 127 x 127 mm - 216 x 381 mm weight: 60 g/m² - 90 g/m² , Input tray - 125 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 177 g/m² , Output tray - 125 sheets , Input tray - 250 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
Speed Details
Copying: up to 19 ppm - B/W , Printing: up to 19 ppm - B/W , Copying: up to 4 ppm - colour , Printing: up to 4 ppm - colour
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows NT 4.0, Apple Mac OS 9.2.2, Apple Mac OS X 10.2.8, Apple Mac OS X 10.3.x
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
398 watt
Power Consumption Standby
19 watt
Power Consumption Sleep
17 watt
Consumables Included
1 x toner (black) - up to 5000 pages , 1 x toner (cyan) - up to 4000 pages , 1 x toner (magenta) - up to 4000 pages , 1 x toner (yellow) - up to 4000 pages
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
UL, GOST, CISPR 24, EN 60950, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B
ENERGY STAR Certified
49.8 cm
53.2 cm
57.3 cm
34.2 kg
Sound Emission
66 dBA (operating)
Resources
The following resources are available for the HP Colour LaserJet 2840 All-in-One series Printer / Fax1 / Scanner / Copier
Customer reviews
Write a review for the HP Colour LaserJet 2840 All-in-One series Printer / Fax1 / Scanner / Copier here!
HPLJ2840
Reviewed by Anonymous Review Posted 27/06/2008
I am now just buying my third unit. Great all round All-in-one and for the price with cash back not to be missed!
Networked they are easy to use for scanning to. Saves on desk space!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Great Printer
Reviewed by Anonymous Review Posted 12/12/2007
Don't believe all the guff you see here - this is a great piece of equipment at a fantastic price with very low running costs! It might be a little noisier than others - but the output is outstanding. If you need more memory, just pop on to www.crucial.com, pick up a bargain and pop it in yourself! With £200 cash back - what more could you want?
  • Overall 5*
  • Ease of use 5*
HP Color Laserjet 2840
Reviewed by Peter Finch. Review Posted 12/10/2006
Generally works fine as specified. One problem is that certain graphics can take literally 10 minutes to achieve 'first page out'. HP can offer no solution or work-round. This may be common to other printers but is very frustrating.
  • Overall 5*
  • Ease of use 4*
  • Value for money 4*
Read all 6 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
