HP CC06XL (long life) Lithium Ion 6-cell 5100 mAh Battery
Quicklinx: 95ZCWS00 Mfr#: 628670-001
The HP Long Life Battery helps you be productive with your notebook longer than with standard solutions, an industry first, helps lower your cost of ownership significantly.
Construction includes an insulating safety wrap that encloses the cells, a fire-retardant casing, barrier walls that isolate cells from the Printed Circuit Assembly (PCA), and internal connections designed to prevent pinching and potential short circuits.
HP CC06XL - laptop battery - Li-Ion - 5100 mAh
Laptop battery
323 g
Long life - Lithium Ion 6-cell - 5100 mAh
4.7 cm x 20.5 cm x 2 cm
EliteBook 8460p Notebook, 8460w Mobile Workstation, 8560p Notebook; Mobile Thin Client 6360t; ProBook 6360b, 6460b, 6465b, 6560b, 6565b
Laptop battery
Long life
6-cell Lithium Ion
Voltage Provided
10.8 V
5100 mAh
Recharge Time
2.5 hours
45 °C
4.7 cm
20.5 cm
2 cm
323 g
HP EliteBook 8460p Notebook, 8460w Mobile Workstation, 8560p Notebook , HP Mobile Thin Client 6360t , HP ProBook 6360b, 6460b, 6465b, 6560b, 6565b
