HP Business Inkjet 2800 - printer - colour - ink-jet
HP Business Inkjet 2800 Drucker
Quicklinx: 3K7BWS00 Mfr#: C8174A#612
The HP Business Inkjet 2800 Printer series is the powerful, cost efficient, A3+ printer series. Experience low running costs with individual high-capacity ink cartridges, exceptional print quality and professional networking for small work teams.
  • Create fast and vibrant documents from postcard(A6) to poster(A3+)with up to 4800-optimised dpi
    Produce vibrant documents in a variety of media and sizes with speed and accuracy. This printer enables fast draft speeds - up to 24 ppm black, 21 ppm colour in laser-quality black text and bright colours with up to 4800-optimised dpi.
  • Enjoy low running cost with four individual high-capacity ink cartridges and long-life printheads
    Save money with this printer. Four individual high-capacity ink cartridges (69 ml black and 28 ml colour) and long-life printheads reduce running cost over life of the printer. Plus you save on paper costs with optional two-sided printing.
  • Experience robust connectivity, easy network management and integration into any environment
    EIO internal print server and industry-standard PCL 5c, PCL 6 and Postscript Level 3 Emulation provide work teams up to 15 users with seamless network connections. Experience easy management with Web Jetadmin and Remote Management Software (RMS).
Printer Type
Workgroup printer - ink-jet - colour
13.5 kg
English / United Kingdom
Max Media Size
A3 plus (329 x 423 mm)
Max Media Size (Custom)
330 mm x 1270 mm
Print Speed
Up to 24 ppm - black draft - A4 (210 x 297 mm) , Up to 21 ppm - colour draft - A4 (210 x 297 mm) , Up to 12.5 ppm - black fast - A4 (210 x 297 mm) , Up to 12 ppm - colour fast - A4 (210 x 297 mm) , Up to 4 ppm - best - A4 (210 x 297 mm) , Up to 5 ppm - colour normal - A4 (210 x 297 mm) , Up to 6.5 ppm - black normal - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
4800 x 1200 dpi
Image Enhancement Technology
HP PhotoREt III
Parallel, USB
256 MHz
RAM Installed (Max)
96 MB (544 MB) - SDRAM - DIMM 100-PIN
Language Simulation
PCL 5C, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, greeting cards, labels, plain paper, photo paper, index cards, cards
Total Media Capacity
150 sheets
Monthly Duty Cycle (max)
12000 pages
Printer Features
Optional duplex
Apple MacOS X 10.2, Microsoft Windows 2000 / XP, Apple MacOS X 10.1.5
Microsoft Certification
Certified for Windows Vista
1-year warranty
67.6 cm x 49.8 cm x 19.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB
1200 x 600 dpi
4800 x 1200 dpi
HP PhotoREt III
PostScript Support
Standard
Language Simulation
Printer Features
Optional duplex
256 MHz
RAM
RAM Installed (Max)
96 MB / 544 MB (max)
Technology / Form Factor
Media Handling
Media Type
Max Media Size
330 mm x 1270 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), C4 (229 x 324 mm), A6 (105 x 148 mm), A3 plus (329 x 423 mm), C5 (162 x 229 mm), C6 (114 x 162 mm), B6 (125 x 176 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm)
150 sheets
Media Feeders
1 x automatic - 150 sheets - A3 plus (329 x 423 mm)
Max Media Capacity
400 sheets
Duty Cycle
12000 pages
Expansion Slots
2 x memory - DIMM 100-PIN , 1 x EIO
1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
VCCI, C-Tick, BSMI, GS, FCC Part 15 B, CCC, MIC
Power supply - internal
Frequency Required
50/60 Hz
67 Watt
Power Consumption Stand by / Sleep
12 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 98 - Pentium - 90 MHz - RAM 16 MB - HD 130 MB , Windows ME - Pentium - 150 MHz - RAM 32 MB - HD 130 MB , Windows 2000 - Pentium II - 300 MHz - RAM 64 MB - HD 160 MB , Windows XP - Pentium - 233 MHz - RAM 64 MB - HD 160 MB
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
15 °C
35 °C
15 - 80%
67.6 cm
49.8 cm
19.9 cm
13.5 kg
3K7B HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £15.62
Resources
The following resources are available for the HP Business Inkjet 2800 - printer - colour - ink-jet
