HP AC Adapter 40W
HP AC Adapter 40W
Quicklinx: 9RVSWS00 Mfr#: 693717-001
Be productive throughout the day and keep your lightweight adapter on hand. This adapter is versatile and can power different HP devices.
HP Smart - power adapter - 40 Watt
Power adapter - external
245 g
Input Wiring
3-phase
Output Voltage
9.5 V
Power Capacity
40 Watt
9.3 cm x 4 cm x 3 cm
Mini 5102 (40 Watt), 5103 (40 Watt)
Input Wiring
3-phase
Frequency Required
47 - 63 Hz
Output Voltage
9.5 V
Power Capacity
40 Watt
UL, BSMI, cUL, GS, NOM, CCC, PSB, PSE Mark, S Mark, KC
5 °C
35 °C
9.3 cm
4 cm
3 cm
245 g
HP Mini 5102 (40 Watt), 5103 (40 Watt)
