HP 17.3 Powerup Backpack
Quicklinx: F6Z0WS00 Mfr#: 1JJ05AA
Get past your fear of power-failure with this revolutionary backpack. A built-in battery gives you the remarkable ability to charge your laptop, tablet, and smartphone wherever you are. Beautifully functional and exceptionally efficient, it's got the power to take you further.
  • Protects against overheating
    A built-in heat sensor monitors backpack temperature and adjusts accordingly.
  • Cleared for takeoff
    Meets security requirements for in-flight carry-ons.
  • Built to protect
    Heavy-duty canvas exterior with interior padding and durable straps helps provide long-lasting laptop protection.
  • Easy access smartphone pocket
    Easily access and use your phone while it's charging.
  • Laptop and USB micro cables included
    Two USB micro cables for Android devices and one laptop cable included.
  • Water resistant
    Coated to resist wet weather and comes with its own raincoat.
HP Powerup - notebook carrying backpack
Notebook carrying backpack
Package Content
HP Power Pack Plus 22400, 2 USB to Micro-USB cables (1m), 19V 3.5mm barrel to 4.5mm barrel cable (1m), 19V 4.5mm to 7.4mm adapter, 19V 7.4mm to 4.5mm adapter
49.98 cm x 33 cm x 16 cm
1.92 kg
Notebook Compatibility
17.3"
Built-in rechargeable battery
1-year warranty
HP 24X G6, 250 G4, 250 G5, 250 G7, 25X G6; ProBook 11 G1, 430 G3, 430 G4, 430 G5, 430 G6, 440 G3, 440 G4, 440 G5, 440 G6, 450 G3, 450 G4, 45X G5, 45X G6, 470 G4, 640 G2, 64X G3, 64X G4, 650 G2, 650 G4, 65X G3; ProBook x360; ZBook 14 G2, 14u G4, 14u G5, 15 G4, 15u G2, 15u G5, 17 G4, Studio G4
Package Content
49.98 cm
33 cm
16 cm
1.92 kg
17.3"
Limited warranty: - 1 year
HP 240 G6 Notebook, 245 G6 Notebook, 250 G4 Notebook, 250 G5 Notebook, 250 G6 Notebook, 250 G7 Notebook, 255 G6 Notebook , HP Chromebook 11 G4, 11 G4 Education Edition, 11 G5, 11 G5 Education Edition, 11A G6 Education Edition, 13 G1, 14 G4, 14 G5 , HP Chromebook x360 14 G1 , HP Elite x2 1012 G1 , HP EliteBook 1030 G1 Notebook, 1040 G3 Notebook, 1040 G4 Notebook, 725 G4 Notebook, 745 G4 Notebook, 755 G4 Notebook, 820 G3 Notebook, 820 G4 Notebook, 830 G5 Notebook, 840 G3 Notebook, 840 G4 Notebook, 840 G5 Notebook, 840r G4 Notebook, 850 G3 Notebook, 850 G4 Notebook, 850 G5 Notebook , HP EliteBook Folio 1020 G1, 1040 G2 , HP Pro Tablet 608 G1 , HP ProBook 11 G1 Notebook, 430 G3 Notebook, 430 G4 Notebook, 430 G5 Notebook, 430 G6 Notebook, 440 G3 Notebook, 440 G4 Notebook, 440 G5 Notebook, 440 G6 Notebook, 450 G3 Notebook, 450 G4 Notebook, 450 G5 Notebook, 450 G6 Notebook, 455 G5 Notebook, 455 G6 Notebook, 470 G4 Notebook, 640 G2 Notebook, 640 G3 Notebook, 640 G4 Notebook, 645 G3 Notebook, 645 G4 Notebook, 650 G2 Notebook, 650 G3 Notebook, 650 G4 Notebook, 655 G3 Notebook , HP ProBook x360 11 G2 Education Edition Notebook, 11 G3 Education Edition Notebook , HP Spectre Pro x360 G1, x360 G2 , HP Stream Pro Laptop 11 G3, 11 G4 Education Edition , HP x2 210, 210 G2 , HP x360 310 G2 , HP ZBook 14 G2 Mobile Workstation, 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 15 G4 Mobile Workstation, 15u G2 Mobile Workstation, 15u G5 Mobile Workstation, 17 G4 Mobile Workstation, Studio G4 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
