HP - DDR4 - 8 GB - SO-DIMM 260-pin
Quicklinx: CKK4WS00 Mfr#: P1N54AT
Boost the capabilities of your HP Business Desktop PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that’s been tested for seamless system-level integration with HP PCs.
Supported by HP
Protect your investment with the same world-class HP limited warranty you get for your PC.
  • Flexible, fast scalability
  • HP-tested
    Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP PCs.
  • Supported by HP
HP - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
HP P1N54AT
1-year warranty
HP 260 G2; Elite Slice, Slice for Meeting Rooms; EliteDesk 705 G3 (mini desktop), 800 G2 (mini desktop); EliteOne 800 G2; ProDesk 400 G2 (mini desktop), 600 G2 (mini desktop); ProOne 400 G2, 600 G2; Retail System MP9 G2; RP9 G1 Retail System 9015, 9018, 9118
8 GB
Upgrade Type
System specific
HP P1N54AT
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL15
Non-ECC
Unbuffered
Voltage
1.2 V
1-year warranty
HP 260 G2 , HP Elite Slice, Slice for Meeting Rooms , HP EliteDesk 705 G3 (mini desktop), 800 G2 (mini desktop) , HP EliteOne 800 G2 , HP ProDesk 400 G2 (mini desktop), 600 G2 (mini desktop) , HP ProOne 400 G2, 600 G2 , HP Retail System MP9 G2 , HP RP9 G1 Retail System 9015, 9018, 9118
