Brand
Kingston 8GB DDR4 2400MHz ECC Module
Quicklinx: CWL1WS00 Mfr#: KTH-PN424E/8G
Type: DDR4 SDRAM
Capacity: 8GB
Connection: SO-DIMM 260-pin
Speed: 2400MHz
Data Integrity: ECC
£42.64 ex VAT
£51.16 inc VAT
Kingston 8GB DDR4 KTH-PN424E/8G HP 2400MHz ECC Unbuffered RAM Memory SODIMM.
Kingston - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL17
ECC
Unbuffered
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
