Smart Home Alarm Kit with GPRS
Contains:
1 x evohome security hub with Standard SIM Card with roaming services
1 x Wireless pet-immune motion sensor
1 x Wireless door and window sensor
1 x Wireless, contactless tag reader with built in siren
2 x Tags
1 x Ethernet cable
Transmission using GPRS with built-in antenna (Smart Wire-less Home Alarm Kit with GPRS and Siren)
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
- Honeywell evohome HS922GPRS - home security system
- Product Type
- Home security system
- Functions
- Siren
- Power Source
- Battery, power adapter
- Package Content
- Door and window sensor, motion sensor, security hub, tag reader
- Connectivity
- Wireless, wired - Ethernet - Cellular
- Product Type
- Functions
- Siren
- Power Source
- Package Content
- Components
- Security hub , Motion sensor , Door and window sensor , Tag reader
- Connectivity Technology
- Mobile Network Supported
- GPRS
- Included Accessories
- Network cable, 2 tags
