Product
Hive Window or Door Sensor
Quicklinx: D2CRWS00 Mfr#: ICEWDSENSOR
£24.17 ex VAT
£29.00 inc VAT
Enjoy life to the full, knowing that everything’s safe at home with our Hive Window or Door Sensor.
  • Get notifications if a door or window is opened when you’re away
  • Attach and set up in seconds
  • Use with Hive Actions to save on heating and lighting
Enjoy your night out
Check you shut the bedroom window properly on the Hive app.
Know when your kids are home
Our Window or Door Sensor will send you a notification when the front door is opened or closed.
Hive Window or Door Sensor - door and window sensor
Door and window sensor
Power Source
Wireless
Power Source
Wireless
