Hama's well designed and extremely flat profile make this wall mount perfect for space saving. The easy-fix system and fully adjustable orienatation is simple to use.
- Hama "Next Light" mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- 44 cm x 4.2 cm x 18.5 cm
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 23"-42"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 300 x 100 mm, 200 x 100 mm, 300 x 300 mm, 200 x 300 mm, 300 x 400 mm
- Max Load Weight
- 50 kg
- Material
- Steel
- Black
- 44 cm
- 4.2 cm
- 18.5 cm
- Material
- Steel
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 23"-42"
- Adjustments
- Tilt
- Max Load Weight
- 50 kg
