The HERO12 Black Creator Edition is an all-in-one content capturing powerhouse that makes vlogging, filmmaking and live streaming easier than ever. Packing pro quality 5.3K60 video and Emmy Award-winning HyperSmooth 6.0 video stabilisation, it puts all the tools you need to tell your story in the palm of your hand. It features High Dynamic Range (HDR) video and photo, a variety of aspect ratios (including full frame 8:7) and 10-bit encoding with GP-Log to deliver the best footage possible and maximum post-production flexibility. The versatile battery grip delivers over 5 hours of 4K recording time per charge1 and features built-in buttons that let you comfortably control the camera during long shoots. This complete system also has a directional microphone that reduces ambient noise, Bluetooth audio for use with your wireless mic, an LED light and multiple options for transferring footage including wireless, wired and with your SD card
What’s Included
HERO12 Black Camera
- Carrying Case
- Enduro Battery
- Curved Adhesive Mount
- Mounting Buckle + Thumb Screw
- USB-C Cable
Volta (Battery Grip / Tripod / Remote)
- USB Pass-Through Door
- Thumb Screw
- USB-C Cable
- Lanyard
Media Mod
- Removable Windscreen
- Vertical Mounting Buckle
Light Mod
- Light Diffuser
- 2-Finger Adapter
Jaw-dropping 5.3K video
5.3K delivers best-in-class image quality with 91% more resolution than 4K. HERO12 black also captures in 4K, 2.7K and 1080p video resolutions. -
Up to 8x slo-mo
Get 4x slo-mo - that's 120 frames per second - at a ridiculously high 4K resolution. You can also ramp up the slo-mo to 8x - 240 frames per second - at 2.7K. -
Ultra durable +
Waterproof to 33 feet and built to take a beating. -
Water-repelling lens cover
Hydrophobic lens sheds water to keep your shots crystal clear when you're in the water. -
Emmy -winning video stabilization
HyperSmooth 6.0 continues to raise the bar for in-camera video stabilization, giving you impossibly smooth footage no matter how rough it gets. And it's winning awards, too - an Emmy Award for In-camera sensor and software stabilization. -
AutoBoost
With HyperSmooth 6.0, HERO12 black automatically ensures you get the widest shots possible while using video stabilization depending on your speed and movement in the scene. -
Built-in horizon lock
Horizon Lock is a built-in part of HyperSmooth 6.0, so it's easier than ever to keep the horizon level when your camera rotates a full 360°. -
Ultra-wide angles in 4K
Get an expansive field of view that's 36% wider than HERO12 black alone4 for amazing views of your bike or skis, and it makes the video look faster and more immersive - all in stunning 4K60. -
Vertical Capture for social media
4K60 Vertical Capture dramatically expands your field of view by up to 48%5 without additional mounts or needing to rotate the camera for immersive POV that's ready for social media. -
Now with longer runtimes
Thanks to its improved power management, HERO12 black delivers 2x longer continuous recording at 5.3K60 (70 minutes), plus over 1.5 hours at 5.3K30 and over 2.5 hours of continuous recording at 1080p30. -
Cold-weather Enduro battery included
Using advanced technology, the long-lasting Enduro Rechargeable Battery boosts performance in cold temperatures over previous GoPro cameras and batteries. -
HDR video
HDR (High Dynamic Range) Video delivers greater detail and color in highlights and is now available in 5.3K and 4K60. -
Shoot wide screen, vertical or full frame
With a tap, switch between wide screen or vertical capture depending on whether you're shooting for traditional wide-screen playback or social media. Or capture in full frame and decide later in the Quik app for maximum versatility. -
Ultra wide-angle digital lenses
HyperView and SuperView - both GoPro exclusive digital lenses - enable ultra wide 16:9 capture, standard in HERO12 black. For even wider shots, consider the new Max Lens Mod 2.0 accessory (see above). -
156° field of view in full 8:7
The large image sensor also lets you capture a wide 156° field of view in a full-frame 8:7 aspect ratio, in 5.3K and 4K. -
10-bit color
10-bit color enables enhanced color depth, smoother gradations and more realism. And pro creators can use GP-Log encoding with LUT to max out dynamic range before applying color correction. -
TimeCode Sync
Wirelessly synchronize multiple HERO12 blacks via timecode in the Quik app. It's perfect for when you want to capture an activity from multiple angles and then make precise, match-frame edits in post-production. Use matching timecode clips in Adobe Premiere Pro and other applications that support multi-camera editing for your next project. -
Bluetooth audio support
Now you can use your Apple AirPods, Bluetooth earbuds or other wireless mics during interviews or narration. You can also give voice commands remotely and hear alerts from your camera. -
Stunning 27MP photos + 24.7MP frame grabs
Just point and shoot for frame-worthy photos. And you can grab high-res, ready-to-share photos right from video. -
Dual LCD screens
Get smooth, snappy playback on the super responsive rear touch screen, and flip to the front screen to frame selfies. -
Star trails
Use the Earth's rotation and stars to capture beautiful light trails in the night sky. -
Hindsight
Hindsight captures up to 30 seconds of footage before you start recording - even if you press the shutter button too late, you'll still get the shot. -
Scheduled + duration capture
With scheduled capture, your GoPro will turn itself on and automatically capture a shot up to 24 hours in advance. Duration capture makes it easy to capture video clips from 15 seconds to 3 hours long. -
Interval Photo
Interval photo can automatically capture photos at fixed intervals while you stay focused on your favorite activities.
- GoPro HERO12 Black - Creator Edition - action camera
- Product Type
- Action camera - 5.3K
- Action Camera Type
- Mountable
- Intelligent Assistant
- Direct
- Memory Card Slot
- microSD card
- Image Processor
- GP2
- Wireless Interface
- Wi-Fi, Bluetooth
- Sensor Resolution
- 27.6 MP
- Lens System
- Wide-angle lens 12 - 39 mm - f/2.5
- Focus Adjustment
- Focus free
- Image Stabiliser
- Electronic (HyperSmooth 6.0)
- Display
- LCD display - 2.27"
- Display (2nd)
- LCD display - 1.4" - colour
- Supported Battery
- 1720 mAh (included)
- Interface
- USB-C
- 7.18 cm x 3.36 cm x 5.08 cm
- 121 g
- Product Type
- Camcorder Sensor Resolution
- 27.6 MP
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/1.9"
- Frame Rate (Max Resolution)
- 60 fps
- Image Processor
- GP2
- Image Stabiliser
- HDR Mode
- SuperPhoto + HDR
- Digital Video Format
- H.265, HEVC
- Image Recording Format
- RAW, JPEG
- Audio Signal Format
- WAV
- Interface
- USB-C, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
- Connectivity Features
- Live streaming (1080p), wireless video upload to cloud server, wireless image upload to cloud server
Exposure & White Balance
- Special Effects
- Star trails, Light painting, vehicle light trails
- Exposure Compensation
- ±2 EV range
Lens System
- Wide-angle lens 12 - 39 mm - f/2.5 - wide angle
- Focus Adjustment
- Focus free
- Max View Angle
- 156 degree(s)
Additional Features
- Continuous Shooting Speed
- 6 frames per second, 10 frames per second, 5 frames per second, 3.3 frames per second, 3 frames per second
- Self-Timer Delay
- 3sec, 10 sec
- Low Lux / Night Mode
- Additional Features
- HDR image enhancement technology, horizon leveling, horizon lock, HindSight, duration capture, schedule recording in power-off mode, time code, built-in speaker, Dual LCD screens, auto boost, voice control, PC webcam option, interval shooting mode
Action Camera Features
- Camera Type
- Mountable
- TimeWarp video recording, Loop recording
Tripod Mount
- Connection Point
- 1/4"-20 screw
Display
- 2.27" LCD display
- Display Form Factor
- Built-in
- Touch Screen
Camera Display (2nd)
- LCD display
- Diagonal Size
- 1.4 in
- Colour Support
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB (USB Type-C)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Voice Controlled
- Direct
- Included Accessories
- Battery grip, media mod, LED light mod, additional battery
- Protection
- Waterproof
- Underwater Depth
- Up to 10 m
- Battery Type
- Manufacturer-specific
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card
- Memory Card Included
- No
- Image Storage
- 5568 x 4872
- 7.18 cm
- 3.36 cm
- 5.08 cm
- 121 g
- Weight Details
- Camera only: 121 g , Camera with battery and mounting fingers: 154 g
- -10 °C
- 35 °C
GoPro Enduro for HERO 12 /11 | In Stock | £20.83 |
GoPro Contacto | In Stock | £66.66 |
