GoPro Contacto
GoPro Contacto
Quicklinx: HXQVWS00 Mfr#: ADCON-001
11 In Stock
£66.66 ex VAT
£79.99 inc VAT
Keep your GoPro charged and max out your recording time—even when you’re in the middle of the action—with the Contacto Magnetic Door and Power Cable Kit. It lets you skip battery changes while you’re on the road or trail and stay powered through activities, long sporting events and time-lapse shots. Simply install the door on your camera and connect the power cable to the door, then plug into any USB-C power source to juice up. Your battery doesn’t even have to be installed. The door is also waterproof to 10 m, so you don’t have to re-install your original door when shooting under water.
1 Make sure that your USB-C power source is waterproof when using in wet conditions. 2 Although the Contacto door is waterproof to 10 m, the complete kit (cables and door) is not intended for underwater use.
What’s Included
  • Contacto Door
  • Contacto USB-C Cable 0.5 m
  • Contacto USB-C Cable 1.2 m
  • Adapter Cable for Volta and USB-C
GoPro power adapter kit - magnetic
Power adapter kit
Action camera
Output Connector Type
Magnetic - on cable: USB-C
Cables
USB-C cable - 0.5 m , USB-C cable - 1.2 m , USB-C adapter
HERO10 Black; HERO11 Black; HERO12 Black; HERO13; HERO9 Black
Power adapter kit
Action camera
Input Connectors
24 pin USB-C
Output connectors
Magnetic
Detachable Cable Connector Type
USB-C
Weatherproof, magnetic fixation
Limited warranty - lifetime
GoPro HERO10 Black , GoPro HERO11 Black , GoPro HERO12 Black , GoPro HERO13 , GoPro HERO9 Black
Brand: GoPro
