The GA-7PESH3 gives you nothing less than the possibility to build a full-blown super workstation within a standard full tower desktop case. With up to 16 cores, 32 threads, 4 double slot GPU/co-processors, and connections for a storage array of up to 13 drives, your workflow can be accelerated with many teraflops of pure computing power.
Supports 4-way SLI and CrossFireX
In order to deliver the big computing acceleration to advanced workstation applications, the GA-7PESH3 can be equipped with up to four NVIDIA Tesla and Intel Xeon Phi co-processing cards, or with up to four NVIDIA Quadro or AMD FirePro cards working together in SLI/CrossFire modes. -
Unique memory performance
This board is an extremely high-value building block for memory demanding workstation applications, thanks to its ability to outperform its competitors in memory frequency. Achieved through Gigabyte's capabilities in design, PCB layout and BIOS fine-tuning, this feature will be appreciated in workstation applications where improvements in memory performance results in significant improvements of the user's workflow. -
Digital power control
The GA-7PESH3 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processors and memory with an ultra-fast response time. Built with advanced calibration tools, they allow to get the pure and efficient electrical supply. When the CPU workloads vary in function of the applications running, the Intel Turbo Boost technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPUs operations are much more stable, and the overall reliability of the system is greatly improved.
- Gigabyte GA-7PESH3 - 1.0 - motherboard - SSI EEB - LGA2011 Socket - C602
- Product Type
- Motherboard - SSI EEB
- Chipset Type
- Intel C602
- Processor Socket
- 2 x LGA2011 Socket
- Compatible Processors
- Xeon E5-2600 series
- Max RAM Size
- 256 GB
- RAM Supported
- DDR3, ECC, registered, unbuffered
- Storage Ports
- 8 x SAS (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 6 x USB 3.0 + 4 x USB 2.0 + (1 x USB 3.0 + 1 x USB 2.0 via headers)
- Graphics
- ASPEED AST2300
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Chipset Type
- Intel C602
- Processor Socket
- LGA2011 Socket
- Max Processors Qty
- 2
Supported RAM
- Max Size
- 256 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Registered, unbuffered
- Quad channel memory architecture
- Details
- 256 GB - registered - ECC , 64 GB - unbuffered - ECC
Graphics
- Graphics Controller
- ASPEED AST2300
Audio
- High Definition Audio
LAN
- Network Controller
- Intel 82574L
- Network Interfaces
- Expansion Slots
- 2 x CPU , 8 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 3 x PCIe 3.0 x16 (x8 mode) , 3 x PCIe 3.0 x8
- Storage Interfaces
- LSI Logic LSISAS2008: SAS -connectors: 8 - 8 devices , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 1E / RAID 10 , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 1E / RAID 10
- 4 x USB 2.0 , 1 x serial , 1 x VGA , 4 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x management , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
- Internal Interfaces
- 2 x USB 3.0 - Type A , 1 x USB 2.0 - header , 1 x audio - header , 1 x USB 3.0 - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- IPMI support, iKVM support
- Hardware Features
- NVIDIA 4-way SLI Technology Support, AMD CrossFireX technology support
- 33 cm
- 30.5 cm
