Gigabyte ATX E3-1200 DIMM Dual Gbe LAN
Quicklinx: B9LKWS00 Mfr#: GA-6UASV3
The GA-6UASV3 is a single socket motherboard addressed to small and medium businesses wishing to benefit from all the main features expected from an entry-level server or workstation of today's technological standards, but at an efficient cost and without compromising high performances. It answers the main needs of small and medium businesses applications in terms of memory intensity, expansion possibilities and server management capabilities, and is therefore the perfect candidate to gear your server base for the future.
  • The ideal base for SMB server infrastructure
  • Support of PCIe generation 3.0
    With the support of the PCI Express generation 3.0 technology directly on the CPU, the GA-6UASV3 is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of its expansion accessories.
Gigabyte GA-6UASV3 - 1.0 - motherboard - micro ATX - LGA1155 Socket - C202
Motherboard - micro ATX
Chipset Type
Intel C202
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Xeon E3-1200 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, ECC, unbuffered
Storage Ports
6 x SATA-300 (RAID)
USB / FireWire Ports
5 x USB 2.0 + (4 x USB 2.0 via headers)
Graphics
ASPEED AST2150
Dedicated Video Memory
128 MB
LAN
2 x Gigabit Ethernet
Chipset Type
Intel C202
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Xeon E3-1200 series
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
ASPEED AST2150
128 MB
LAN
Network Controller
Intel 82574L / Intel 82579LM
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 3.0 x8 , 1 x PCIe 3.0 x8 (x4 mode) , 1 x PCI
Storage Interfaces
SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 4 x USB 2.0
Internal Interfaces
4 x USB 2.0 - header , 1 x serial - header , 1 x USB 2.0 - Type A
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
24.4 cm
24.4 cm
