This USB Display Adapter enables you to connect one more monitor, LCD or projector to a computer with a USB 2.0 port. For desktop users adding an extra monitor via USB, connection is easier than ever. No more having to open the computer chassis to install an internal video card. Once the installation is complete, the USBattached monitor soon wakes up. No function key hassle to swap to a second monitor.
Convenient USB-to-video
Add-on monitor, LCD or projector through a single USB 2.0 port. -
Hot plug
Add or remove monitor without system reboot. -
Small and slim
Works with all VGA / DVI-I displays. -
High resolution output
Up to 2048x1152. -
Video streaming
Up to 1080p and up to 6 USB display adapters to work simultaneously.
- Fujitsu USB Display Adapter - external video adapter - black
- External video adapter
- Bus Type
- USB 2.0
- Max Resolution
- 1440 x 1050
- DVI-I
- 5.4 cm x 1.8 cm x 8.4 cm
- Enclosure Colour
- Black
- Designed For
- CELSIUS Mobile H700, H710, H910, H970; ESPRIMO C910, D556, D757, D757/E94, D956, D957, D957/E94, E400, P556, P756, P756 E94, P956/E94, P957, Q520, Q956; LIFEBOOK E554, E751, E780, E781, LH531, P3110, P701, P770, P771, PH530, S710, S751, S760, S761, T580, T730, T731, T900, T901, TH700; Stylistic Q550
- Bus Type
- USB 2.0
- Max Resolution
- 1440 x 1050 at 85 Hz
- DVI-I
Video Output
- Supported Display Graphics
- VGA (640x480), XGA (1024x768), SVGA (800x600), SXGA (1280x1024), 1280x960, 1440x900, 1366x768, 1440x1050
- OS Required
- Microsoft Windows XP, Microsoft Windows Vista
- Additional Requirements
- CD-ROM, USB port
- System Requirements Details
- 1.2 GHz - RAM 256 MB - HDD 30 MB
- Cables Included
- 1 x USB cable - 1 m
- Software Included
- Drivers & Utilities
- Plug and Play
- 5.4 cm
- 1.8 cm
- 8.4 cm
- Enclosure Colour
- Black
- 10 °C
- 35 °C
- 8 - 85% (non-condensing)
- Designed For
- Fujitsu CELSIUS Mobile H265, H270, H700, H710, H910 Dual Core, H910 Quad Core, H970 , Fujitsu ESPRIMO C910-L, D556/2/E85+, D556/E85+, D556/E90+, D757/E85+, D757/E90+, D757/E94+, D956/M (International Energy Star Program), D957/E85+, D957/E90+, D957/E94+, E400 E85+, P556 E85+, P556 E90+, P556/2/E85+, P756 E85+, P756 E90+, P756 E94+, P956/E94+, P957/power, Q520/K, Q956/MRE , Fujitsu ESPRIMO Mobile D9510, M9410, M9415, U9210, U9215, V6505, V6535, V6545, X9510, X9515, X9525 , Fujitsu LIFEBOOK E554, E751, E780, E781, E8010, E8010 Mainstream, E8010 Supreme, E8310, E8420, LH531, P3110, P701, P770, P771, P8010, P8020, P8110, PH530, S6420, S710, S7220, S751, S760, S761, T1010, T5010, T580, T730, T731, T900, T901, TH700 , Fujitsu Stylistic Q550
