Fujitsu Eth Ctrl 2x1Gbit PCIe PRO1000
Quicklinx: 718ZWS00 Mfr#: S26361-F3228-L1
Conserve valuable PCI Express (PCIe) server slots while adding multi-port Gigabit Ethernet capability with the Intel PRO/1000 PT Dual Port Server Adapter. The dedicated input/output (I/O) bandwidth of PCIe ensures priority performance on each port, without bus sharing, for Gigabit Ethernet connectivity in Category-5 networks. Additionally, the Intel PRO/1000 PT Dual Port Server Adapter is designed to provide high performance in multi-processor systems by efficiently balancing network loads across multiple Central Processing Units (CPUs) when used with Receive-Side Scaling from Microsoft or Scalable I/O on Linux.
The Intel PRO/1000 PT Dual Port Server Adapter features 10/100/ 1000 Mbps self-configuration for compatibility with mixed-speed network devices, and is supported by Intel PRO Intelligent Install and the new Intel PROSet Utility for Microsoft Device Manager. Intel PROSet simplifies adapter installation and gives you point-and-click power to configure and manage all your Intel PRO Network Connections for connectivity you can count on.
Intel PRO/1000 PT Dual Port Server Adapter - network adapter - PCIe x4 - Gigabit Ethernet x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
PCI Specification Revision
PCIe 1.0a
Ports
2.2 cm x 12.9 cm x 12 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Intel 82571EB
IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), WfM 2.0
SCO OpenServer 5, Microsoft Windows 2000, Novell NetWare 5.x, SunSoft Solaris x86 8, Novell NetWare 6.x, Caldera OpenUnix 8, Linux 2.4 or later, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Datacenter Edition, FreeBSD 4.x
PRIMERGY RX330 S1, RX600 S4, TX150 S6, TX200 S3, TX200 S4, TX200 S5, TX300 S5
Network adapter
Plug-in card
PCI Express x4
PCIe 1.0a
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Remote Management Protocol
SNMP, DMI 2.0
Status Indicators
Port transmission speed, link OK
Full duplex capability, ACPI support, auto-negotiation, WOL
Processor / Memory
Intel 82571EB
2 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x4 - full-height
FCC Class B certified, UL, VCCI, C-Tick, BSMI, MIC
2.2 cm
12.9 cm
12 cm
55 °C
Fujitsu PRIMERGY RX330 S1, RX600 S4, TX150 S6, TX200 S3, TX200 S4, TX200 S5, TX300 S5
