Fujitsu ETERNUS DX60 ISCSI
Quicklinx: 7DKLWS00 Mfr#: VFY:DX600XF050IN
ETERNUS DX60 entry level disk storage systems can either connect to hosts via Fiber Channel, iSCSI or SAS. It is easy to install, configure, operate and maintain, integrating well with host operating systems, servers, network infrastructures and backup solutions. Different disk types can be mixed and matched, secured by the relevant monitored RAID levels (0, 1, 5, 1+0, 5+0 and 6) and features to ensure data integrity. Administrators can dynamically move data, spin disks down to save energy or encrypt disks to prevent unauthorized access. In the event of power outages, the content of the cache is secured to flash memory. A backup copy is always at hand via snapshots and clones.
Fujitsu ETERNUS DX 60 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
2 TB
iSCSI
2 (installed) / 12 (max)
Supported Drives
SAS
Storage Controller
RAID (SAS) - RAID 0, 1, 5, 6, 10, 50
Storage Controller Quantity
1
Hard Drive
2 x 1 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
48.3 cm x 65 cm x 8.8 cm
35 kg
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
2
Supported Devices / Modules Qty
12
Supported Drives
SAS
Storage
2 TB
HDD Array External Interface
iSCSI
Storage Controller
RAID (iSCSI)
Installed Qty
1
Interface Type
SAS
Cache / Buffer Size (Max)
1 GB
Supported Devices
Disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50
Storage Controller (2nd)
Installed Qty
1
Hard Drive
HDD - hot-swap
2 x 1 TB
Spindle Speed
7200 rpm
Expansion Bays
12 (total) / 10 (free) x hot-swap - 3.5"
1 x Ethernet 1000 , 1 x Ethernet 1000Base-T (management)
C-Tick, BSMI, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, VCCI Class A ITE, EN55024, EN55022 Class A, ICES-003 Class A, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A
2 x internal power supply - hot-plug
Max Supported Qty
2
48.3 cm
65 cm
8.8 cm
35 kg
5 °C
20 - 80%
