Smart Modular, 80 PLUS and single 12V rail!
The key features
* Dedicated single 12V-rail, powering a total of 50A
* 100% real wattage - this PSU delivers what it claims to do!
* Smart Modular - all modular cables have the same type of connection, making it easy to connect the way you want and also making it future proof
* Silent and 80 PLUS certified - save your ears and the environment
* Quality - Durability and extremely low failure rate
* Five years warranty
Smart Modular!
With having an universal connection from the PSU, it makes it easier to connect your perihperals the way you want.
The power and efficiency - 80 PLUS!
When you buy a Fractal Design power supply, you can rest assured that you get what you pay for. 100% real wattage, we guarantee that it can run with continous load on the specified wattage. One other important factor with this PSU is that it has a very good efficiency, well over 80% and 80 PLUS certified by the 80 PLUS organisation.
The silence
Apart from being powerful, this power supply won't break your ears. On the contrary, it will be hard to know if it's actually running or not! With a hand picked, high quality 120mm fan mounted with rubber fittings, the fan will only spin as much as needed under the different loads. The high efficiency of well over 80% is crucial, since it minimizes the heat the power supply emits, enabling the fan to spin at lower speeds and be more silent.
The Quality
Every manufacturer claims to have this, but we have real life numbers to show: less than 1% in RMA rate is an impressively low number. We value durability when creating our power supplies, we never choose to save costs when choosing the components inside the power supply. As an example, we use long durable japanese capacitors in the PSU.
* 80 PLUS certified
* 650W continous load capacity, 810W peak load capacity
* At normal load (<350W) the fan speed will be lower than 700rpm
* Extra long cables to support full tower cases
* Industrial grade, high quality Japanese capacitors for optimal performance and reliability
* Active PFC delivers clean and reliable power
* Supports ATX12V 2.3, EPS12V 2.91/2.92 and older ATX12V v2.01
* Full range universal input 115V-230V
* Over Current/Voltage/Power Protection, Under Voltage Protection and Short Circuit Protection
* Safety approvals for CE, EMC and LVD
* Multi-language manual
* Size (D x W x H, mm): 140 x 150 x 86
Cable configuration
* 1x 20/24-pin, 1x 8pin(4+4pin), 2x PCI-Express, 8x SATA connectors, 10x Molex 4-pin connectors, 1x Floppy
Fixed cables
* 1x 20/24-pin, 65cm long
* 1x 8(4+4)-pin, 65cm long
Modular cables
* 2x PCI-express 8-pin(6+2) cable, each 45cm long
* 1x SATA cable, 4 connectors, total 95cm long
* 1x SATA cable, 4 connectors, total 80cm long
* 1x Molex 4-pin cable, 4 connectors, total 95cm long
* 1x Molex 4-pin cable, 4 connectors, total 80cm long
* 1x Molex 4-pin/Floppy cable, 2+1 connectors, total 65cm long
