Fractal Design EDISON M Series (650W) Power Supply Unit
Quicklinx: B39ZWS00 Mfr#: FD-PSU-ED1B-650W-UK
The Fractal Design Edison M series of power supplies feature excellent electrical performance, including 80PLUS Gold certified efficiency.
Designed for maximum reliability, the Edison M units feature Japanese electrolytic capacitors with a full protection suite, including over-temperature protection. The modular cable system assists with a clean installation and the extra-long ATX 12 V cable accommodates cases with bottom mounted PSU positions.
Fractal Design Edison M units are equipped with a large, temperature-controlled FDB-bearing 120 mm fan contributing to a maximum lifespan while keeping noise levels at a minimum.
The Edison M is a highly reliable choice, for both gaming computers and powerful workstations.
  • 80 PLUS Gold certified efficiency
    Edison M PSUs meet the 80 PLUS Gold specification for providing power at an extremely competitive price point, priving excellent value. Additionally, because Edison M PSUs generate less heat, they provide power at lower fan speeds, which results in reduced noise levels.
  • Superb Electrical Performance
    Fractal Design Edison M Series PSUs feature excellent DC voltage regulation and ripple suppression: they can deliver their full-rated wattage continuously even with an intake temperature as high as 40 °C at full load or 50 °C at 80% load.
  • Compliant with the latest standards
    Edison M PSUs are compliant with the PC PSU standard: ATX 2.4/EPS 2.92.
  • High end capacitors
    Edison M PSUs feature Japanese electrolytic capacitors, rated at 105 °C as well as Japanese and Taiwanese solid polymer capacitors.
  • Silent, temperature-controlled 120 mm FDB fan
    Generally, larger fans move more air with less noise than smaller fans: Edison M Series PSUs are equipped with a 120 mm FDB bearing, which keeps noise levels at a minimum.
  • Extra-long ATX 12 V cable
    Edison M PSUs are equipped with an extra long 12 V connector cable, which accommodates bottom-mounted-PSU computer cases.
  • Computer protection
    Edison M PSUs feature a full suite of computer protection, including: Over Power Protection, Over Voltage Protection, Short Circuit Protection, Under Voltage Protection, Over Current Protection and Over Temperature Protection.
Fractal Design Edison M 650W - power supply - 650 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
2.4 kg
United Kingdom
Power Capacity
650 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V1 - 54 A , -12V - 0.3 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 5 x 4 PIN internal power
Modular Cable Management
Cooling System
120 mm fan
Cable ties
15 cm x 16 cm x 8.6 cm
5-year warranty
PSU Form Factor
ATX
United Kingdom
Power Capacity
650 Watt
Output Current
80 PLUS Gold
Cable ties
MTBF
100,000 hours
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, DC-DC technology, Intel 4th-gen CPU (Haswell) compatible, fluid dynamic bearing cooling fan
ErP 2013
Limited warranty - 5 years
15 cm
16 cm
8.6 cm
2.4 kg
Shipping Width
29.9 cm
Shipping Depth
12.2 cm
Shipping Height
18.5 cm
Shipping Weight
3 kg
