Fractal Design 1000W Tesla Wired 80+ Gold PSU
Quicklinx: 8B9PWS00 Mfr#: FD-PSU-TS2B-1000W
Fractal Design Tesla R2 series power supply units provide clean power efficiently and quietly. The Tesla R2 is an excellent choice for demanding high-end gaming computers and powerful workstations. The visual appearance of Tesla R2 series PSUs is proof of Fractal Design's commitment to providing innovative computer components infused with stylish, elegant, contemporary Scandinavian design.
  • 80 PLUS Gold certified efficiency
    Tesla R2 series PSUs meet the 80 PLUS Gold specification for providing power with an efficiency that surpasses most power supplies available today. This efficiency produces positive environmental impact, as well as reduces electricity bills. Additionally, because Tesla R2 PSUs generate less heat, they provide power at lower fan speeds, which results in reduced noise levels.
  • Excellent electrical performance
    Tesla R2 series PSUs feature excellent DC voltage regulation and ripple suppression; they can deliver their full-rated wattage continuously even with an intake temperature as high as 40 °C.
  • SLI and CrossFireX support
    Tesla R2 series PSUs (650 W and up) are tested and certified compatible with the latest graphics cards.
  • Silent, temperature-controlled 135 mm fan
    Generally, larger fans move more air with less noise than smaller fans: Tesla R2 series PSUs are equipped with a large, low-speed, 135 mm fan, which keeps noise level down.
  • Single powerful 12 V rail
    To provide maximum support for modern components, Tesla R2 series PSUs deliver their full power from a single 12 V rail.
  • Extra-Long ATX12V cable
    Tesla R2 series PSUs are equipped with a 700 mm long 12 V ("P4") connector cable, which accommodates bottom-mounted-PSU computer cases.
Fractal Design Tesla R2 - power supply - 1000 Watt
Power supply - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Gold
Input Voltage
AC 115/230 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V - 80 A , -12V - 0.5 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 2 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
135 mm fan
Cable ties
15 cm x 16.5 cm x 8.6 cm
3-year warranty
ATX12V 2.31
PSU Form Factor
ATX
Input Voltage
AC 115/230 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Output Current
80 PLUS Gold
Cable ties
Power cable
MTBF
100,000 hours
Cooling System
135 mm fan
SLI ready, single 12V rail, temperature controlled fan, ball bearing cooling fan, CrossFireX ready
Limited warranty - 3 years
15 cm
16.5 cm
8.6 cm
Shipping Width
10.5 cm
Shipping Depth
24.5 cm
Shipping Height
29.5 cm
