Fortinet FortiSwitch 448D Switch
Quicklinx: CJPLWS00 Mfr#: FS-448D
FortiSwitch Secure Access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate Network Security Platform, the FortiSwitch Secure Access switches can be managed directly from the familiar FortiGate interface. This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect.
When a device connects to a Secure Access Switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
Fortinet FortiSwitch 448D - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 176 Gbps , Latency: 1 µs
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 13
MAC Address Table Size
16K entries
Remote Management Protocol
CLI
1.5MB packet buffer
44 cm x 31 cm x 4.4 cm
4.15 kg
Enclosure Type
Rack-mountable 1U
Ports
Performance
16K entries
CLI
1.5MB packet buffer
RAM
1 GB
Flash Memory
128 MB
48 x 1000Base-TX RJ-45 , 4 x 10Gbit LAN SFP+ , 1 x 1000Base-T RJ-45 management , 1 x console RJ-45
Internal power supply
17.3 Watt
MTBF
10 years
UL, VCCI, BSMI, CB, FCC, RoHS2, RCM
44 cm
31 cm
4.4 cm
4.15 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
