Fairphone USB-C 3.2 LONG-LIFE CABLE
Quicklinx: GRL9WS00 Mfr#: 000-0046-000000-0003
This lifetime-lasting, multi-purpose USB-C 3.2 cable is reinforced with braided kevlar and nylon for exceptional durability and is designed to withstand the toughest industrial-grade stress tests (You can twist it over 50.000 times and it will keep on going). The strain relief is made from bio TPU and there’s a handy velcro-organizer attached.
The cable has futureproof C-to-C connectors and comes with the flexibility of a USB-C to USB-A adapter. It gives you the latest performance of supporting 3A and transfer speeds up to 10 Gbps, for example between your laptop and a portable hard drive. Never worry about charging cables again and cut down on e-waste with the cable that’s designed for true longevity.
Charging and data cable
USB-C to USB-C
USB-C to USB-A with adapter
USB 3.2 Gen 2x1 standard
As Fairphone 3 and Fairphone 3+ charge at 5V, you cannot experience the full performance of this charging cable. Your phone will experience a maximum of 15W charging performance.
Warranty
2 years
Braided black and yellow
lengh
1.2m
