Ezviz Ultra HD 4MP Indoor Smart Security Pan/Tilt Cam with Motion Tracking
Quicklinx: H0W9WS00 Mfr#: CS-C6W-A0-3H4WF
  • microSD Card
Elegant and versatile, the C6W camera is all the protection you need for a large home. It records in 2K resolution and automatically tracks motion in 4x zoom to make sure nothing escapes the eye.
  • Records every corner in 2K resolution
    The small but powerful camera records images in 2K resolution, rendering crisp details even in 4x digital zoom.
  • Auto-zoom motion tracking, especially for human movements
    After enabling the auto-zoom tracking function, the camera automatically zooms in up to 4 times to track a moving object so you can easily tell what's going on when viewing live. In the app, it also offers the option to track motion that is specifically human.
  • Whole-room coverage is a breeze
    Keep tabs on every corner with just one C6W camera. Its expansive 360-degree field-of-view ensures a full coverage, so you won't miss a thing.
  • True-WDR for truly clear images
    The C6W Camera uses sensor-based True-WDR technology to eliminate overexposure or underexposure in high-contrast scenes, delivering evenly-bright images from dawn to dusk.
  • Two-way talk
    Use the EZVIZ App on your mobile device to call home when you are away. You'll love the opportunity to have a two-way conversation now that both sides can speak to and hear each other - just like a normal phone call.
  • See clearer, even in the dark
    The C6W camera uses two powerful infrared lights to render sharp nighttime imaging up to 10 meters away. It is smart enough to automatically switch between day and night vision so you can rest assured knowing your home and belongings are protected 24/7.
  • H.265 Video Compression
    The camera features the advanced H.265 video compression technology, achieving better video quality with only half the bandwidth and half the storage space of the previous H.264 video compression standard.
EZVIZ C6W - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
9.58 cm x 9.58 cm x 9.06 cm
252 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Motion Detection
Video Modes
2K
Optical Sensor Type
PS CMOS - 1/2.7" - 4 MP
Minimum Illumination
0.5 lux - colour - F2.0 - AGC on , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
4 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0
Panning Range (degree)
340
Tilting Range (degree)
75
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Backlight Compensation (BLC), progressive scanning, saturation control, brightness control, contrast control, image mirror, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR), smart tracking, self-adaptive shutter, motion detection, Person Detection, Auto-Zoom Tracking
1-year warranty
Environmental Parameters (operating)
-10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wired, wireless
9.58 cm
9.58 cm
9.06 cm
252 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
H.264, H.265
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
2K
Digital Zoom
4
Infrared LEDs
Infrared Distance
10 m
Image Sensor
4 MP PS CMOS 1/2.7"
Lens Construction
M12 mount - fixed focal
Focal Length
4 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
83
Vertical Field of View (degree)
57
Diagonal Field of View (degree)
104
Panning
Range (degree)
340
Tilting
Range (degree)
75
Network Interface
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card
Camera mount base, screw kit, drill hole template
UL, NOM, IC, FCC, RoHS, WEEE, REACH
Power Requirements
DC 5 V
Power adapter - external 8 Watt
Limited warranty - 1 year
Shipping Width
12.6 cm
Shipping Depth
12.6 cm
Shipping Height
16 cm
Shipping Weight
513 g
-10 °C
45 °C
Relative Humidity (operating)
