Introducing the EZVIZ Full HD Wi-Fi Outdoor Camera
The EZVIZ Floodlight is a weatherproof (IP65) outdoor floodlight with a powerful 2500LM brightness and built-in Full HD 140-degree view camera and 100dB Alarm system. The Floodlight can replace an existing outdoor light unit, or be installed as a new unit. Furthermore, with the 270 Degree PIR sensor, you will get motion detection alerts to your EZVIZ app and be able to select areas of detection to avoid false alarms, and two way-audio solution built-in also. Professional Installation Recommended, available via ezvizlife.com/uk
Be Informed
Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Light it up
Featuring PIR human detection, the Floodlight sends an instant alert to you when a human is approaching, whilst activating the bright floodlight feature with a powerful 2500LM brightness. The 270 degree PIR sensor means intruders cannot evade detection, even if trying to go against the wall or under the floodlight. With up to 60ft range in night vision mode, you are protected, even in the dark
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
24/7 All Season Protection
Because of its IP65 enclosure rating, the Outdoor camera will be resistant against rain, snow, and other weather conditions. With the integration of Infrared technology, footage can be seen clearly at Night too.
Two-way Talk
Integrated with professional de-noising algorithm to filter background noise for enhanced voice quality. The internal waterproof MIC supports audio pickup within five meters and video recording with sound via the EZVIZ app.
Easy Setup
Straight Forward installation with drill template included in the box. The camera itself has a Cardan shaft rotation for various angles, great for both ceiling and wall-mounted installation. For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Works with EZVIZ Alarm Systems
Link to a specific EZVIZ alarm sensor via the app to ensure footage begins straight away when a sensor is triggered, helping capture the whole event from all angles.
What’s in the box
- 1x EZVIZ Full HD Wi-Fi Outdoor Floodlight
- 1x Power Adapter with 7.5 Meters total Power Cable
- 1x Screw and cable Kit
- 1x Quick Start Guide
Light the way back home
With dual 2500 LM LED lights, the LC1 brightens up your way home and illuminates every dark corner of your front porch, backyard, and anywhere else that needs light. -
Extra protection with active defense
When someone enters LC1's 270-degree PIR motion detection area, it emits a 100 dB alarm with flashing light to deter potential intruders. It simultaneously sends an alert with captured images to your smartphones. You can also customize the detection area to keep an eye on places where you need it the most. -
Sharpest night guard
The LC1 supports night vision up to 18 meters. It renders sharp, Full HD 1080p images even where there are no lights, so you keep a vigilant eye all night long. -
Strong and durable
Built for outdoor use, the LC1 braves any weather - sun, rain, or snow, it stands strong.
- EZVIZ LC1 - network surveillance camera
- Network surveillance camera - fixed - outdoor - dustproof / waterproof
- Audio
- Yes: built-in speaker, two-way audio capability, built-in omni-directional microphone
- 19.6 cm x 21.1 cm x 22.7 cm
- 1.757 kg
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 3 - connection cable
- Backlight Compensation (BLC), PIR-based motion detector, 2 LED lamps, built-in siren, noise reduction, 3D Digital Noise Reduction Technology, embedded Linux, 270-degree motion detection angle
- Environmental Parameters (operating)
- -30 °C - 50 °C; 0 - 95% (non-condensing) relative humidity
- Audio Support
- Wireless
- 19.6 cm
- 21.1 cm
- 22.7 cm
- 1.757 kg
Camera
- Colour - Day&Night - fixed - outdoor - dustproof / waterproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 18 m
- Frame Rate (max)
Lens Construction
- Horizontal Field of View (degree)
- 115
- Diagonal Field of View (degree)
- 140
- Network Interface
- Supported Memory Cards
- microSD Card
- Included Accessories
- Screwdriver, screws, 3 waterproof kits
- Cables Included
- 3 x connection cable
- IP65
- Power Device
- Power adapter AC 110/240 V 8 Watt
- Shipping Width
- 23.5 cm
- Shipping Depth
- 25 cm
- Shipping Height
- 27 cm
- -30 °C
- 50 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
